What Mods Can I Do To My R Spec Without Blowing The Engine Or Auto ?
  • Member For: 16y 8m 11d
from what ive seen on here it isnt that simple they are way more advanced than the 4 speed. do a search for zf transmission cooler on here. If you do attempt it make sure you post your results. I'd love to do it for track days.
  • Replies 55
  • Created
  • Last Reply
Top Posters In This Topic
  • Member For: 19y 1m 8d
if he does it like his mate it will be a under battery mounted cooler with a fan mounted on it running a digital fridge thermo controler. :fish:
  • Member For: 15y 11m
I'm fitting a oil cooler to my zf this weekend, so Ill tell you how it goes.
  • Member For: 15y 11m 1d
yeah cool awesome hope it goes all well :beerchug:
  • 3 weeks later...
  On 15/11/2009 at 12:02 AM, R-SPEC said:
You don't need valve springs dude.
Get:
- Wastegate ported, 38mm flapper valve and a 12psi or 15psi actuator
- 4" airbox
- Fuel pump
- 60lb injectors
- 4" dump and a good cat
yeah mate where is a good place to get these done
was told there is only 1 place in aus to get turbo done in mel somewhere like turbo something the place is called ??? can any1 tell the number..
also is 38mm flapper big enough or bigger is better ???
  • Member For: 18y 11m 5d
there are plenty of places that can mod the turbo wastegate, some better than others, start with your tuner first
yeah maybe so but not where I live :roflmbo: I live on the sunshine coast QLD my tune was at redcilf dyno and all he says is u carnt go much more than I already have without blowing my engine :blaah::blaah:
and all I have atm is 292 rwks :stirthepot::roflmbo:
  • Member For: 15y 6m 20d
A good start is how much money do you want to spend.
process west surge tank are cheap and good for the power.
60lbs injectors .
exchange turbo housings are pretty cheap (labour is the killer).
I have a 3.5inch split dump pipe sitting at work, flows as well as a 4inch.
battery relocation is easy you could put it in a battery box in the boot, plus you could do it yourself
rapid do a nice four inch intake pipe
Xtreme Ford Tuning do a exchange 6sp zf good for 500kw+
