What Mods Can I Do To My R Spec Without Blowing The Engine Or Auto ?
R_Spec_Matt
  • Member For: 15y 8m 11d
YEAH hi guys
I would like to find out what can I do to me engine with out killin it ???
Mods already done to my engine : Prosses West plenum chamber and intercooler , green top injectors 420 cc , flash turner , exhaust (have to find out what size it is , I forgat atm lol@me),
I got 292 rwkws @ 12 psi... I think I got about 1600 ft lbs torque dont realy know how to read the dyno sheet probly....
mods I aint got yet : surge tank, bigger fuel pump 4" dump pipe , 5" cat
anything else I need guys would be good to know or if I need better stuff than what I already have .....
also how much kws can I run before my auto slips or breaks ??????
thanks guys ......
  • Replies 55
  • Banned
  • Member For: 15y 6m 25d
boost it up to 17psi or so, 4" dump and nocat/gutted cat. Bigger injectors again id say. 660cc's. Then your at about 350rwkw then your bout at your limits...
YEAH thx for reply *Beep*.... whats the typhoons auto like ???? u think the auto will handle 350 kws near abouts ?????
also what size exhaust u think ????
thx mate....
YEAH also do I need heavy duty valve springs ?????
can I use a home made surge tank or I need a pro 1 made ????
Edited by R_Spec_Matt
  • Member For: 17y 10m 8d
adding a surge tank wont give you more power.
all a surge tank does is allow you to run less fuel at the drags or on the street without running into fuel surge. also means you have less weight at the strip.
I would be throwing a set of valve springs in next, a decent dump pipe and cat, getting your wastegate modified and a larger actuator fitted. and quite possibly upgrading your injectors.
your engine and gearbox should be able to withstand the power gained with these mods depending on how competant your tuner is.
yeah thx for reply .... when I have about 1/2 to 3/4 of a tank and at high revs it surge's real bad....
