Watto89 Member 38 Member For: 16y 8m 22d Gender: Male Location: Townsville Posted 13/11/09 01:47 PM Share Posted 13/11/09 01:47 PM G'day, I just did a lot of work to my car including Rapid v3.0, 4" dump, 5" cat, twin 2'5" catback, valve springs, 60lb injectors, walbro fuel pump. 326rwkw with 15 boostI gave my car a bit today and the engine light came on, I stopped my car and no oil was dropping or anything, my mate rkns it could be my car going "WTF is going on with all these new sh*t" bit I wanted to see you guys opionions..Thanks Link to comment https://www.fordxr6turbo.com/forum/topic/63558-engine-light-after-mods/ Share on other sites More sharing options...
GreenXR6T Donating Members 630 Member For: 19y 8m 16d Gender: Male Location: NSW Posted 13/11/09 10:25 PM Share Posted 13/11/09 10:25 PM I had the same after some mods and a tune, it ended up being the O2 sensor.Get your tuner (or a local mechanic) to fit a scan tool to read the fault codes. Link to comment https://www.fordxr6turbo.com/forum/topic/63558-engine-light-after-mods/#findComment-953710 Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 9m 13d Gender: Male Location: Newcastle Posted 13/11/09 10:44 PM Share Posted 13/11/09 10:44 PM Your tuner should have tuned out the second O2 sensor after the cat to stop it from sending a faulty cat code to the ecu. Talk to him and ask if he has. It may be another issue causing the light if he has.Benny Link to comment https://www.fordxr6turbo.com/forum/topic/63558-engine-light-after-mods/#findComment-953715 Share on other sites More sharing options...
