  • Member For: 22y 1m 29d
I was wanting to modify my car but it is a lease car and I don't want anyone to tell. Does any one have a picture od the stage 1 aps kit cause I would like to see how it looks. Also does any one know any other modification, eg exhuast from >???? for so dollars for 12 kw at the real wheels.
Any comments would be appricaiated.
https://www.fordxr6turbo.com/forum/topic/6338-modifications/
  • What's happening?
  • Member For: 22y 4m 28d
According to David from APS and Con from C&V here in Sydney, the stage 1 APS kit should be almost undetectable. They go to great lengths to install the unichip in a hidden location, and none of us could see any trace of the unichip or it wiring at the info day last weekend. And we did try!
Obviously they wouldnt tell us where it is installed, as the less people that know where it installed, the less that people get issues with their ford dealers.
Unless they pull the whole front end apart they shouldnt find it.
Not a bad upgrade, approx $1600 for 30kw.
https://www.fordxr6turbo.com/forum/topic/6338-modifications/#findComment-51862
  • I see red
  • Member For: 22y 4m 15d
The only difference visually between stock and APS Stage 1 is two wires going to the ECU instead of one. The extra wire is covered in the same convuluted tubing as the factory. Only a XR6T expert would pick it.
Exhaust is an interesting one. Chris (CFJ077) said he had no power gain from his but Iaschmidt said he did from his (can't recall figure).
MS700 put an XR8 air filter assy on his XR6T recently and appears to have made a small gain. Other people have changed to different brands of panel filters such as K&N
Xr8 Air Cleaner, Fitted to XR6T
Cold Air Intake Air @ Air Filter, performance
K&n Panel Air Filter
Bmc Air Filter Kw Improvement
https://www.fordxr6turbo.com/forum/topic/6338-modifications/#findComment-51945
  • Member For: 22y 6m 22d
  wicksy said:
hey I was wondering wat can I do to increase the power of my non turbo xr6?
Easy mate, just trade it in on a turbo. Or spend $7,000 putting a supercharger on it. Or about the same for an aftermarket turbo installation.
https://www.fordxr6turbo.com/forum/topic/6338-modifications/#findComment-51965
  • Member For: 21y 9m 17d
I just ran this exact kit past my insurance and they said flat out no. Wouldn't touch it. Leasing companies don't like mods.
And you can bet an assessor would find it if you bumped into a nice new Roller and its legal team.
https://www.fordxr6turbo.com/forum/topic/6338-modifications/#findComment-52080
  • My new toy
  • Member For: 22y 10d
Yes 3.5 inch from turbo back two mufflers straight though type approx 22 rwkw gian it has to be 3.5 inch 3 inch is to small.
Ian
https://www.fordxr6turbo.com/forum/topic/6338-modifications/#findComment-52108
  • My new toy
There is starting to be some mods done for the n/a I have driven a ute and there is a marked differance to proformance no supercharger or turbo fitted.
There is thread on here called the n/a is back have a look at it and it will give some idea of what is happerning.
Ian
https://www.fordxr6turbo.com/forum/topic/6338-modifications/#findComment-52109
  • Faster than any BTA,XTC,Autotech, Nizpro and Tunehouse car
  • Member For: 21y 10m 10d
you say 3.5 inch exhaust gave you 22 rwklw and you have a stage 1 boost box running 10 psi giving you 228rwklw, I just put the same boost kit on running std exhaust no cold air intake and got 226rwklw in my auto running 8 psi ? :thumbsup:
https://www.fordxr6turbo.com/forum/topic/6338-modifications/#findComment-52135
  • Member For: 22y 4m 8d
  xr6ikness said:
you say 3.5 inch exhaust gave you 22 rwklw and you have a stage 1 boost box running 10 psi giving you 228rwklw, I just put the same boost kit on running std exhaust no cold air intake and got 226rwklw in my auto running 8 psi ? :pukeup:
Here we go again :D
You can't compare performance unless the cars are tested on the same Dyno, in same mode and under identical conditions.
I would raise serious questions to whoever installed and tested your 8 psi kit, as I run an automatic with 3" turbo back stainless exhaust, cold air intake and 9 psi of boost, and my performance is 200 rwkw.
I have run my car against a manual and automatic both in standard configuration (1axr & mr walker), and on that Dyno I tested to around 225 rwkw, well above the standard cars.
Just be careful to get realistic numbers on your claimed performance increase, before comparing to other modified XR6T's :)
https://www.fordxr6turbo.com/forum/topic/6338-modifications/#findComment-52161
