falcon_6 Member 29 Member For: 16y 4m 30d Gender: Male Location: Bringelly NSW Posted 07/11/09 08:12 AM Share Posted 07/11/09 08:12 AM Just wondering if some of you turbo folks out there can offer comments on my slight problem.I'm running stage 3 process west kit and the usual goodies with 380rwkw 16psi as my daily gay tune.Now have any of you came across issues with oil leaks from the engine due to the crank case pressurizing.This is generally caused by blowby from high boost levels.Now since I'm running large power levels do I require extra crank case ventilation( the one in the middle of the rocker cover not the pcv)?If so what is the best way to go by thiss? Link to comment Share on other sites More sharing options...
