mattyb Donating Members 1,097 Member For: 16y 10m 24d Gender: Male Location: Gold Coast, QLD Posted 02/02/10 10:33 AM Share Posted 02/02/10 10:33 AM Sweet, cheers for that, it's always great for people to share their knowledge. Cheers ratter. Link to comment https://www.fordxr6turbo.com/forum/topic/63375-where-to-buy-bigger-flapper-for-wastegate-mod/page/3/#findComment-977424 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 18y 11m 13d Gender: Male Location: Central Queensland Posted 02/02/10 11:24 AM Author Share Posted 02/02/10 11:24 AM Thanks for the info Ratter... I take it, that the flat section of the port must remain... Well I guess that the port will not be drilled out, but will now be hand ported (Enlarged and edges smoothed).... : Link to comment https://www.fordxr6turbo.com/forum/topic/63375-where-to-buy-bigger-flapper-for-wastegate-mod/page/3/#findComment-977447 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 8m 4d Gender: Male Location: Townsville Posted 02/02/10 02:23 PM Share Posted 02/02/10 02:23 PM I didn't think you could round the edge on the flapper side as you need that good seal?The only way I could see it catching on a flat edge is if the hole was made just short of being to big and the free play on the flapper caught the edge?I understand porting from the back to flow into the flapper as seen in my dogy photo editing but didn't think anywhere else required it. Link to comment https://www.fordxr6turbo.com/forum/topic/63375-where-to-buy-bigger-flapper-for-wastegate-mod/page/3/#findComment-977527 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 18y 11m 13d Gender: Male Location: Central Queensland Posted 08/02/10 07:59 AM Author Share Posted 08/02/10 07:59 AM (edited) Well guys.. I enlarged the wastegate hole and ported the housing today. I have taken the housing to a local machinist to mill the lip off the housing and remove the interferance material where te shaft goes through. This will create a better seal and allow the Folapper to be set into the correct position. All up, it has taken around 2 hours of me just dawdling along. I have taken Rattlers advice and shaped ported the housing similar to getting your heads ported. This will minimise turbelence in the housing and increase the flow through the wastegate.... I have sent the to a machinist to mill the lip off and remove the interference material from around the shaft where it comes through the housing. This will allow for a larger port and better seating of the flapper. I will post up some pics of the porting when I get it back later in the week... Edited 08/02/10 08:04 AM by HI PSI Link to comment https://www.fordxr6turbo.com/forum/topic/63375-where-to-buy-bigger-flapper-for-wastegate-mod/page/3/#findComment-979414 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 18y 11m 13d Gender: Male Location: Central Queensland Posted 11/02/10 07:47 AM Author Share Posted 11/02/10 07:47 AM (edited) Got my housing back from the machinist today. I decided to get the raised factory lip removed and we machined the housing so that the flapper will seat level with the housing. Unfortunately it is a bit too late for some pics and it is overcast also.. So it has made it impossiblr to get any good shots of the porting and machining.. I will post some up tomorrow... Edited 11/02/10 07:50 AM by HI PSI Link to comment https://www.fordxr6turbo.com/forum/topic/63375-where-to-buy-bigger-flapper-for-wastegate-mod/page/3/#findComment-980694 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 8m 4d Gender: Male Location: Townsville Posted 11/02/10 08:02 AM Share Posted 11/02/10 08:02 AM Cheers HI PSI, cant wait for the pics. Hopefully will help me understand it before I give it a try! Link to comment https://www.fordxr6turbo.com/forum/topic/63375-where-to-buy-bigger-flapper-for-wastegate-mod/page/3/#findComment-980701 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 18y 11m 13d Gender: Male Location: Central Queensland Posted 11/02/10 09:23 AM Author Share Posted 11/02/10 09:23 AM Hey BJC... I will make it clear now, that I am no expert in this field. I ported the housing without seeking professional advice. Only Rattler (Thanks Bud) has been kind enough to post some comments with advice.. I have used my own reasoning and ideas on it's flow characteristics. I am hoping that someone with some knowledge will comment and correct me if I have made any errors... I have made a photbucket folder... I know that some of the pics are not the best quality. But you will get an inkling of what I have done...Porting Pics Link to comment https://www.fordxr6turbo.com/forum/topic/63375-where-to-buy-bigger-flapper-for-wastegate-mod/page/3/#findComment-980729 Share on other sites More sharing options...
mattyb Donating Members 1,097 Member For: 16y 10m 24d Gender: Male Location: Gold Coast, QLD Posted 11/02/10 09:51 AM Share Posted 11/02/10 09:51 AM how easy was it to pull the turbo apart? Did you have ani instructions? Link to comment https://www.fordxr6turbo.com/forum/topic/63375-where-to-buy-bigger-flapper-for-wastegate-mod/page/3/#findComment-980739 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 18y 11m 13d Gender: Male Location: Central Queensland Posted 11/02/10 10:06 AM Author Share Posted 11/02/10 10:06 AM This is a spare housing that I purchased some time ago. this is my guinea Pig. So I haven't actually removed it yet.. There are Two "STICKIES" in the Turbo section... Removal of Turbo in Preparation for porting and larger valve PT1Part 2Removal Of Turbo In Preperation Of Porting And Valve Mod Part Ii I recently downloaded a PDF which is what I consider to be a full servicemanual.. Let mI Link to comment https://www.fordxr6turbo.com/forum/topic/63375-where-to-buy-bigger-flapper-for-wastegate-mod/page/3/#findComment-980750 Share on other sites More sharing options...
HI PSI Member 1,589 Member For: 18y 11m 13d Gender: Male Location: Central Queensland Posted 11/02/10 10:48 AM Author Share Posted 11/02/10 10:48 AM (edited) For some reason this reply section comes up all messed up for me.... I cannot see what I have written after a few sentences.... Here is the link for the Manual ...My link Edited 11/02/10 10:49 AM by HI PSI Link to comment https://www.fordxr6turbo.com/forum/topic/63375-where-to-buy-bigger-flapper-for-wastegate-mod/page/3/#findComment-980770 Share on other sites More sharing options...
