Project Manual Typhoon 9 Sec
SPIKO
  • Member For: 19y 9m 28d
It is possible to flat accelerator change with the Magnum but NOT without the clutch LOL :beerchug:
Ps: Yes still H pattern Blake... There is a modification to the slave cylinder (& gearbox) available but not tested that allow's push or pull to shift capabilities (sequential no clutch changes). We will discuss this in more detail once it has landed from the USA and is tested.. (after Christmas) :nono::roflmbo:
Edited by SPIKO
  • Member For: 17y 17d
liberty would be good for drag but hardly drivable on street. a h pattern sequential would be something else. as for flat shifting its all in the clutch, but what is different in the magnum box compared to std ?
u using an opt 6 mr spiro ?? I know mal - at the time I got mine put in - had a special little option that helped flat shifting with the twin plates.
Yes I am using a personalized option 6 Mic, Magnum box is much stronger than its predecessor in every way, much more precise in shifting as well... I run a mix of button & carbon ceramic clutches so that it can be driven on the street, my fly wheel is heavily lightened and my pressure plate is also modified for much more clamp down pressure as well...
Flat changing can be done in many ways, you can also semi flat change as well so you don't blow your gearbox to smithereens with sticky slick tyre's.. You will all soon see this nevertheless not too long to go now, we will also be able to run the car more than once down the track with the recent mod's. This will in turn allow us to try a few approaches at once and hopefully work out the optimum approach in all area's. :innocent::beerchug::icon_ford:
Edited by SPIKO
  • A much better forum
  • Member For: 16y 6m 12d
Is this thing always gonna be manual?
Or once you have a 9 you will think about a nice tuff C4??? or powerglide :icon_ford:
  • Member For: 17y 2m 30d
I vote for a liberty box ;)
Only way to fly, got mine just not to long ago, I got the extreme version, rated at about 3000hp...
Edited by JETFPV
