wookie_666 Member 70 Member For: 15y 7m 19d Posted 02/11/09 07:52 AM Share Posted 02/11/09 07:52 AM ok guys, heres the situation,Only facing up hill, when the car idles for about 30 sec or more, if I give it a rev it blows a thick cloud of white smoke.A few more hits and it goes away, so it clears. It does this on petrol or lpg, and again, only facing uphill, when it idles for a little while. Not down hill, or on a level surface. It has a burning smell. Could it be coolant, oil, water, internals, or a seal. Ive been told it could be running a bit lean, but it does it on gas and lpg. and only when up hill. So I dont think its too lean. Its like something builds up while idling, then clears after a few good revs.Please help, im getting a service on saturday, and I want some ideas to tell the mechanic. Link to comment Share on other sites More sharing options...
Xrfranjo Member 350 Member For: 17y 4m Gender: Male Location: Bonnyrigg Heights, NSW Posted 02/11/09 07:54 AM Share Posted 02/11/09 07:54 AM I could be wrong but could be valve stem seals... Link to comment Share on other sites More sharing options...
wookie_666 Member 70 Member For: 15y 7m 19d Posted 02/11/09 07:57 AM Author Share Posted 02/11/09 07:57 AM again, it only does it up hill, but are the valve stem seals hard to fix and expensive, and what do they do exactly? Link to comment Share on other sites More sharing options...
wookie_666 Member 70 Member For: 15y 7m 19d Posted 02/11/09 08:55 AM Author Share Posted 02/11/09 08:55 AM from what I can understand, its actually water. because it doesn't smell like fuel, oil, or coolant.the exhaust tip has a few drops from it, on what would be a hot day. but where could the water be coming from? any ideas Link to comment Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 6m 4d Gender: Male Location: Earth Posted 02/11/09 09:02 AM Share Posted 02/11/09 09:02 AM Please help, im getting a service on saturday, and I want some ideas to tell the mechanic.Tell him everything you've written in your first post.No-one on here will be able to tell you what it is without looking at it. If a mechanic is going to be servicing it he will look at it for you. Link to comment Share on other sites More sharing options...
wookie_666 Member 70 Member For: 15y 7m 19d Posted 02/11/09 09:06 AM Author Share Posted 02/11/09 09:06 AM thanks for that, I will. Link to comment Share on other sites More sharing options...
seduced Need more power. Now taking donations. Member 753 Member For: 15y 9m 26d Gender: Male Posted 03/11/09 12:09 AM Share Posted 03/11/09 12:09 AM A cooling system pressure test will help too.White smoke usually means coolant/water leaking into the bores. Then again, yours may be something else entirely. So many varibles! Link to comment Share on other sites More sharing options...
wookie_666 Member 70 Member For: 15y 7m 19d Posted 03/11/09 07:39 AM Author Share Posted 03/11/09 07:39 AM ive been told it could be my oil pickup, how could I check the pickup, is it a matter of actually taking the sump out? again it only does it on a hill so I guess that it may be bent and when the oil is at the back of the sump it just doest pick up.?? please help Link to comment Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 7d Gender: Male Posted 03/11/09 08:13 AM Share Posted 03/11/09 08:13 AM if it wasn't picking up oil, you would think your oil pressure light would come on. Link to comment Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 20y 10m 9d Gender: Male Location: Sydney Posted 03/11/09 09:39 AM Share Posted 03/11/09 09:39 AM You could also have a leaking master cylinder, as brake fluid makes great thick white smoke.When I was a mechanic we used to put a bottle on the vac advanced on clients cars to prank the guy doing the work.If it does it only uphil then the angle could be enough to put a few drips in the booster and get sucked into the inlet tract. It does not take much brake fluid to show smoke.Check the brake fluid level as a precaution. Link to comment Share on other sites More sharing options...
