ebxmple Member 1,322 Member For: 17y 1m Posted 30/10/09 01:50 PM Share Posted 30/10/09 01:50 PM The exhaust manifold to head does have a gasket or it should have anyway... Put a gasket between the turbo and the manifold and use the g lock kit on those 4 studs.. The other 13mm bolts that hold the turbo to the housing always come loose also and fall out if not tightened frequently.. The 13mm bolts usually start to come loose once the housing develops cracks.. The cracks arent tooooo much of a problem but the bolts falling out is. Link to comment Share on other sites More sharing options...
kirjo Member 113 Member For: 15y 8m 15d Gender: Male Location: Brisbane Posted 30/10/09 03:49 PM Share Posted 30/10/09 03:49 PM Hey boys can u all tell the the noise u r hearing? is it a grinding noise below 2000rpm? this is what my 05 BA MKII is doingGrinding noise? Pull the intake hose off the turbo and make sure the compressor wheel isn't touching the housing Link to comment Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 2m 15d Gender: Male Posted 31/10/09 03:24 AM Share Posted 31/10/09 03:24 AM cheers Kirjo. I'll get onto it. Link to comment Share on other sites More sharing options...
kirjo Member 113 Member For: 15y 8m 15d Gender: Male Location: Brisbane Posted 01/11/09 07:38 AM Share Posted 01/11/09 07:38 AM No probs mate. How'd you go? I hope you've checked it! Link to comment Share on other sites More sharing options...
