Fog Light Function Doesnt Work
Toxic Beast
  • Member For: 18y 4m 11d
Hey Fellas
Wondering if anyone knew why
my Foglights wont come on anymore. Cables are perfectly connected
When I push in the fog button, it will click in but the light on the dash wont appear, neither will the foggies come on.
but the LED on the actual button is light if my headlights are one..
Any suggestions.?
Thanks !
  • ANGEL EYES
  • Member For: 16y 5m 14d
Does the button light turn off if you press it? Pretty sure this is on all the time. I would say dead switch IMO. Known to be wrong many times though! LOL. Good luck with it. Switches are only around $10-20 from memory. Checked fuses? Maybe a silly question.
Edited by GR8XR6
  • ORSM Ford Cruisers!
  • Member For: 19y 7m 6d
Check the following.
20A Fog Light Fuse
Fog Lamp Relay
15A Tail Light Fuse
When you press the button you should be able to hear the fog lamp relay click in the engine bay.
20A Fog Light Fuse
Fog Lamp Relay
15A Tail Light Fuse
thanks for the advise. I checked those fuses....
they are fine.
whats the fog lamp relay.?
The relay I'm pretty sure is located in the fuse box located under the bonnet, if you take the lid off there is a diagram indicating which one is which.
Matt
  • Member For: 16y 11m 5d
Yeah fog light relay is in the engine compartment fuse box and it tells you on the inside of the lid and I think in the owners manual,which one it is. Have you checked to see if you have power at the fog light connectors or do you know your globes are ok. If you know what your doing you can bridge the relay to see if they come on which will tell you which part of the circuit you need to check. Are your parkers working? If they arent and your fuses are ok you might even have a dud combo switch.
  • 3 weeks later...
  • voy74656
  • Member For: 21y 1m 18d
Did this end up getting sorted? Would b sik 2 know wtf it was?
I've got the same problem - cant hear the relay click when I press the foggies button. Parkers & fog lights both don't work?
Have replaced all 3 fuses/relays above & no luck?
Voy
  • 1 month later...
