Azid Rush Donating doesnt allow you to be an idiot! Member 692 Member For: 18y 1m 26d Gender: Male Location: Newcastle Posted 29/10/09 12:19 AM Share Posted 29/10/09 12:19 AM Hey guysLately ive been noticing some problems with the box in my ba xr6t. Its just the 4spd auto and ive been noticing its taking some time to change gears, if I go from neutral to reverse, it takes about 5 seconds before it actually clicks into reverse. Also in tiptronic when going down gears it isnt always going from 2nd down to first or takes 5-7 seconds after I shift it than it will jump downIs my box on the way out or could it just be an electrics problem maybe the selonoid?Cheers Guys Link to comment https://www.fordxr6turbo.com/forum/topic/63145-is-my-gearbox-on-the-way-out/ Share on other sites More sharing options...
xr6turboman Donating Members 588 Member For: 17y Gender: Male Location: New Zealand, Palmerston North Posted 29/10/09 01:38 AM Share Posted 29/10/09 01:38 AM How long since you did the transmission fluid?? Link to comment https://www.fordxr6turbo.com/forum/topic/63145-is-my-gearbox-on-the-way-out/#findComment-948351 Share on other sites More sharing options...
Azid Rush Donating doesnt allow you to be an idiot! Member 692 Member For: 18y 1m 26d Gender: Male Location: Newcastle Posted 29/10/09 01:19 PM Author Share Posted 29/10/09 01:19 PM was thinking about that after I posted think its due for a change... Got it done by a mechanic mate last time, ill do it myself this time but how do I do it exactly? Link to comment https://www.fordxr6turbo.com/forum/topic/63145-is-my-gearbox-on-the-way-out/#findComment-948716 Share on other sites More sharing options...
ugy Donating Members 199 Member For: 19y 5m 23d Location: Auckland Posted 29/10/09 10:33 PM Share Posted 29/10/09 10:33 PM Does it do it when the oil is cold.? Mine done the same thing when I took it around the track and over heated it.When it cooled down went back to normal, but 6 months later new gearbox. Link to comment https://www.fordxr6turbo.com/forum/topic/63145-is-my-gearbox-on-the-way-out/#findComment-948770 Share on other sites More sharing options...
Azid Rush Donating doesnt allow you to be an idiot! Member 692 Member For: 18y 1m 26d Gender: Male Location: Newcastle Posted 30/10/09 01:57 PM Author Share Posted 30/10/09 01:57 PM now that you mention it ive kinda only noticed it when the oil is warm, no track work just half hour drive to work.. I hope its not the same thing I dont wanna be up for a new box Link to comment https://www.fordxr6turbo.com/forum/topic/63145-is-my-gearbox-on-the-way-out/#findComment-949039 Share on other sites More sharing options...
ugy Donating Members 199 Member For: 19y 5m 23d Location: Auckland Posted 30/10/09 11:28 PM Share Posted 30/10/09 11:28 PM Don't worry until it start's thumping between gear changes. It could be anything Link to comment https://www.fordxr6turbo.com/forum/topic/63145-is-my-gearbox-on-the-way-out/#findComment-949085 Share on other sites More sharing options...
Tiga_EL New Member 6 Member For: 17y 11m 19d Posted 18/11/09 10:06 AM Share Posted 18/11/09 10:06 AM Id be checking the amount of fluid in the box first, and getting a service done. Trans cooler would also be quite helpful if not already done. As long as its not slipping it hopefully for your sake should be fine. Link to comment https://www.fordxr6turbo.com/forum/topic/63145-is-my-gearbox-on-the-way-out/#findComment-955179 Share on other sites More sharing options...
ebxmple Member 1,322 Member For: 17y 2m 13d Posted 18/11/09 10:15 AM Share Posted 18/11/09 10:15 AM What speed are you doing when you try and select first? Maybe your going a bit too quick for the trans to want to shift into first. The big delay into reverse is a worry though and maybe first signs to start saving. If you do get a trans service done,make sure you take it to a trans place as they should do it properly and shim the band. They can also do a leak test of the clutch packs etc when the valve body is off. Alot more involved than just changing oil and filter if you want it done properly. Link to comment https://www.fordxr6turbo.com/forum/topic/63145-is-my-gearbox-on-the-way-out/#findComment-955187 Share on other sites More sharing options...
