Thru The Gears
cqtiger
  • Member For: 17y 3m 25d
I have a BF mk1 T and just wish for someone to clarify a few things.
I don't often "push" the bionic beast but on occasion I have taken up a challenge. Sometimes with my rev-head son who owns an EL XR8 which he has just modded with a supercharger!??!
Anyway, just wondering, there was a time that he caught me unawares at the lights and in my attempt to reclaim him my power dropped off momentarily in 3rd (rev limiter?) didn't actually see the revs when this happened but it would have been high up there. Can someone confirm the rev limit per gear? I have a stock BF, 6 speed manual. I heard that 6100 rpm is the limit in first gear and then go to about 6000 each other gear. Is this reasonable for a stock T?
  • Need more power. Now taking donations.
  • Member For: 15y 8m 21d
6100 I believe. You must have been moving if you were hitting the limiter in thrid!!! Long "private" road?
Watch your oil pump gears...
  • Member For: 15y 1m 30d
Around 6k sounds about right.
Of course, changing gear will give the best result over 5500.
Rev limiter will be the same in every gear, however the speed limiter should cut engine output at 250kph from memory.
