30,000 Service
fang
  • Member For: 19y 1m 15d
Just had the car serviced ( non ford dealer ), and fingers crossed, very minor issues. Having had an XR6T prior to the G6ET, I was aware of things that can go pear shaped. First up..minor heat shield rattle..had that sorted with some additional anchorage screws.
Under sill fascia ( behind front tyres )..loose. He thinks a bracket may not have been used during assembly. Worth checking if you drive a G6ET.That'll be a warranty job. Front discs squeal..easily sorted. Had him check diff area ( been there. done that with the T ) ..all fine.
cheers
Steve
I have front right disc/pad squeal also. How did you fix yours? Was it a block dust seal in the caliper or the disc?
The work sheet is at the office, but from memory it was a simple fix involving the application of some anti squeal compound.
Steve
