  • Banned
  • Member For: 15y 9m 11d
Anyone cracking 400+rwkw with stock bf typhoon 07/07 model valve springs? My motor has 20,000k's so should be pretty fresh. Dont mind if they wear down later.
anyone pushing 400rwkw with stock phoon 07/07 bottom ends? or known to
  • 4 weeks later...
  • Member For: 17y 3m 30d
Im pushing 395rwkw on 17psi stock bottom end, nizpro valve springs. Tuner says im running on borrowed time with that sort of power. The daily tune is 14psi. I just flash the 17psi in for weekends till I can afford a built motor.
Hope it helps mate
Adam.
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 28d
yes your valve springs in that donk will go over 400 easy
  • 3 weeks later...
  • Member For: 15y 10m 28d
yer hi I've got late 06 typhoon and pushing 450kw at the wheels and runs perfect but trans can't hold the power very long.
  • 3 weeks later...
  • Enforcer
  • Member For: 16y 6m 19d
I have an 07/'07 BFII XR6 T, Would they be the same Valve springs too?
  On 02/12/2009 at 1:34 PM, icer said:
450 with stock valve springs? interesting
the valve springs where stock and ran 20 psi at the top end to make 450 kw atw now it has nizpro ones but changing them to race atomic series
the bottom end is stock and have pushed it to 500kw @the wheels with race fuel.and the bottom end is still fine.
Edited by darios typhoon
