DK777 Member 44 Member For: 15y 10m 27d Gender: Male Location: Northside Brisbane Posted 18/10/09 05:39 AM Share Posted 18/10/09 05:39 AM hey guys, this has probs been covered before though- 3.5"/1.5"split dumpand a 4" dumpand mild steel vs stainless...to suit 100cpi cat, 3.5" systm with 1 muffler.car-bf xr6t utecurrent mods- rapid system v3, 60lb injectors, bosch 044.power figure- chasing 300-350rwkwand have been quoted $1300-1400 for 3.5" split/3.5" systemand $1500-1800 for 4" dump/3.5" or dual 2.5" system (xforce stainless)If you guys could help me with information on spool, power ratings, quality, etc and reputable exhaust shops in the qld brisbane area that would be great. cheers Link to comment Share on other sites More sharing options...
Ozzy Member 40 Member For: 15y 5m 11d Gender: Male Posted 18/10/09 06:13 AM Share Posted 18/10/09 06:13 AM I have a 4" dump pipe, 3.5" cat and 2.5" twins and works well. Wrapped the dump pipe in exhaust wrap.You should expect the exhaust to flow about 1000Hp, so mid 300's will be a walk in the park.Im a Sydney sider, so I cant tell you any good shops up your way but sure someone will let you know soon. Link to comment Share on other sites More sharing options...
DK777 Member 44 Member For: 15y 10m 27d Gender: Male Location: Northside Brisbane Posted 18/10/09 06:31 AM Author Share Posted 18/10/09 06:31 AM thanks mate... did you get a retune straight away after you got the system installed? as ive heard if you have a tune already the system shouldnt spike too much...? Link to comment Share on other sites More sharing options...
Ozzy Member 40 Member For: 15y 5m 11d Gender: Male Posted 18/10/09 07:25 AM Share Posted 18/10/09 07:25 AM Glad to help out mate.I slapped the pipe on and went straight to get tuned up.Ive got a ute aswell. The X-force system works well on it. Have a mate running 400's with the same pipes. I have found it resinates a bit between 1600 and 1900 rpm with the 2 mufflers. It doesnt worry me too much personally but I know there are some people that hate it. Link to comment Share on other sites More sharing options...
Mastika Member 47 Member For: 15y 5m 9d Posted 18/10/09 09:21 AM Share Posted 18/10/09 09:21 AM what places in sydney apart from the sponsors of fordxr6turbo do you guys know of ?probably after a full exhaust system, just want to get some quotes in Link to comment Share on other sites More sharing options...
Casey Spencer Member 43 Member For: 15y 4m 17d Gender: Male Location: qld Posted 18/10/09 09:40 AM Share Posted 18/10/09 09:40 AM I have a 4" dump pipe, 3.5" cat and 2.5" twins and works well. Wrapped the dump pipe in exhaust wrap.You should expect the exhaust to flow about 1000Hp, so mid 300's will be a walk in the park.Im a Sydney sider, so I cant tell you any good shops up your way but sure someone will let you know soon.when does your power come on, a good exhaust will flow low down power to get you started and then mid to top end to keep you going, depends where you want you power 3.5" twin dump pipe /3.5" system good low down power less lag (I would recommend this for mid 300rwkw)4" dump/3.5" or dual 2.5" system (xforce stainless) good top end power more lag and more back psi (I wouldn't recommend ) Link to comment Share on other sites More sharing options...
Casey Spencer Member 43 Member For: 15y 4m 17d Gender: Male Location: qld Posted 18/10/09 09:45 AM Share Posted 18/10/09 09:45 AM dk777 who made your 3.5 inch system Link to comment Share on other sites More sharing options...
Mastika Member 47 Member For: 15y 5m 9d Posted 18/10/09 11:59 PM Share Posted 18/10/09 11:59 PM when does your power come on, a good exhaust will flow low down power to get you started and then mid to top end to keep you going, depends where you want you power 3.5" twin dump pipe /3.5" system good low down power less lag (I would recommend this for mid 300rwkw)4" dump/3.5" or dual 2.5" system (xforce stainless) good top end power more lag and more back psi (I wouldn't recommend )I've heard that a smaller dump like the 3.5" would be better for the mid 300rwkw but what about a high 200rwkw?? would a 3" do the job? Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 21y 5m 8d Gender: Male Location: Perth, WA Posted 19/10/09 12:48 AM Share Posted 19/10/09 12:48 AM I've heard that a smaller dump like the 3.5" would be better for the mid 300rwkw but what about a high 200rwkw?? would a 3" do the job?The factory cast dump is 3" so no point wasting money on getting an aftermarket 3". If you are going to replace the dump then go for either a 3.5" split or straight 4".If you only want high 200's get a high flow metal cat (4.5" or 5" body) and that's all you will need. Link to comment Share on other sites More sharing options...
DK777 Member 44 Member For: 15y 10m 27d Gender: Male Location: Northside Brisbane Posted 19/10/09 01:11 AM Author Share Posted 19/10/09 01:11 AM hey guys im in the process of playing of numerous exhaust shops... so far quoted 3.5" split n single system for $1300 mild steel4" dump n 3.5" single system for $1400 mild steel4" dump stainless with 100cpi stainless cat into twin 2.5" system for $1400 mild steel all fitted... Link to comment Share on other sites More sharing options...
