Help Needed Setting Up Injectors
DCVNXR
  • Member For: 16y 3m 19d
Hi everyone, just thrown in some siemens deka 60s and am having abit of trouble controling the fuel constantly going rich lean rich lean, afr going from 13 to 15.1 at idle.Ive had abit of a search on this site but not much on the actual tuning side of things, im using HPT format and have the specs from the ford racing site.
Any ideas on what ive stuffed up ? what settings are people running? or would anyone be willing to let me read there car in the se suburbs of melb ?
Any help would be great.
  • Member For: 18y 3m 24d
wouldnt you need a custom tune because they are higher flowing injectors.. hence causing it to get rich?
  • Member For: 18y 7m 25d
the specs on that site do not work correctly, even when modified to match our cars, several of us have tried them in the past and although the idle appeared ok with no test equipment, testing them would find the changes you mentioned.
  • Member For: 15y 4m 2d
Sounds to me like your ECU is in a closed loop and the mixture is are cycling to satisfy both sections in the cat.
We have CNG buses at work and when they are in closed loop, the O2 output voltage cycles from 40mV to 929mV when everything is right. 450mV is stoichiometric.
  • Silver Donating Members
  • Member For: 19y 6m 13d
Try either of these, it will get you rolling. Just leave losed loop learning on and the O2 feedback will clean up the slops.
Break Point 0.0000168
High Slope 0.0197
Low Slope 0.0288
Min PW 0.00036
Battery Offset Factory
High Slope 0.019
Low Slope 0.031
Min PW 0.0003
Just be careful with your base fuel table....don't go nuts if you're not watching a wideband.
  • 3 months later...
