CHLAXN Donating Members 932 Member For: 17y 1m 7d Gender: Male Location: north QLD Posted 02/11/09 07:35 AM Share Posted 02/11/09 07:35 AM yeah mate if you want you can leave the box in and hold up with a jack like I did when I pulled my motor out.. I also took my radiator out for some extra room as the FPV clutch is pretty big and you need as much room as you can get to pull it out with out with no scratches. its pretty straight foward Link to comment https://www.fordxr6turbo.com/forum/topic/62744-help-lost-all-oil-pressure/page/4/#findComment-949703 Share on other sites More sharing options...
GeofFGXR6T Member 7 Member For: 16y 3m 24d Posted 02/11/09 07:59 AM Share Posted 02/11/09 07:59 AM For what its worth many years ago I had a brand new VN Late model camira company vehicle. I was driving home one night and the oil light came on. I stopped and checked the oil. Dip stick said ok so I thought faulty indicator and drove home for another 15 minutes. The engine souned ok until I drove down the side of my house where I could now hear the engine noise reflecting of the house brick wall and it sounded like the engine was full of loose metal!! Anyway contacted the dealer fully expecting that the motor was ruined. The dealer fixed a faulty oil pressure relief valve, filled it will oil and I drove the car without any problems for the next 4 years and about 100,000km. Link to comment https://www.fordxr6turbo.com/forum/topic/62744-help-lost-all-oil-pressure/page/4/#findComment-949719 Share on other sites More sharing options...
RUS531 RUS531 Donating Members 410 Member For: 18y 10m 9d Gender: Male Location: Emerald QLD Posted 02/11/09 09:08 AM Author Share Posted 02/11/09 09:08 AM On 02/11/2009 at 7:35 AM, CHLAXN said: yeah mate if you want you can leave the box in and hold up with a jack like I did when I pulled my motor out.. I also took my radiator out for some extra room as the FPV clutch is pretty big and you need as much room as you can get to pull it out with out with no scratches. its pretty straight foward Sweet, that's what I thought. I have taken the radiator out too. I'll post some pics soon. On 02/11/2009 at 7:59 AM, GeofFGXR6T said: For what its worth many years ago I had a brand new VN Late model camira company vehicle. I was driving home one night and the oil light came on. I stopped and checked the oil. Dip stick said ok so I thought faulty indicator and drove home for another 15 minutes. The engine souned ok until I drove down the side of my house where I could now hear the engine noise reflecting of the house brick wall and it sounded like the engine was full of loose metal!! Anyway contacted the dealer fully expecting that the motor was ruined. The dealer fixed a faulty oil pressure relief valve, filled it will oil and I drove the car without any problems for the next 4 years and about 100,000km.Thanks Geoff, I was also thinking this and it could be a possibility you know. When had a look down the front of my timing case the oil pump looked intact and when I dropped the oil yesterday there was no signs of metal.... maybe the same thing has happened. I've heard it happening to other cars aswell. I will still send it down to brad though... I plan on keeping this car for a while and will be aiming for 400rwkw, so a freshen up aswell and some new/tougher hardware should see it there reliably. Link to comment https://www.fordxr6turbo.com/forum/topic/62744-help-lost-all-oil-pressure/page/4/#findComment-949751 Share on other sites More sharing options...
RUS531 RUS531 Donating Members 410 Member For: 18y 10m 9d Gender: Male Location: Emerald QLD Posted 02/11/09 09:46 AM Author Share Posted 02/11/09 09:46 AM Here are some pics of my progress so far. As you can see I had a blown gasket on my turbo/dump pipe. When I first got this car I found that the flange was missing a couple of nuts on the waste-gate side, which I then replaced. This is obviously the result and you can see on the flange where the gasses have been escaping. I wonder how this would have affected my performance, spool times and boost control. I know that boost was creeping past its 14 pound setting (old owner told me about its tunes). I'm off to work for seven days starting tomorrow so she will have to wait to be hoisted out until then. Link to comment https://www.fordxr6turbo.com/forum/topic/62744-help-lost-all-oil-pressure/page/4/#findComment-949775 Share on other sites More sharing options...
RUS531 RUS531 Donating Members 410 Member For: 18y 10m 9d Gender: Male Location: Emerald QLD Posted 11/11/09 07:59 AM Author Share Posted 11/11/09 07:59 AM Ok so I am back from my week at work, now to get stuck back into it.I went and saw a rental mob today and organised myself a 1200kg engine hoist for this week end for 5o bucks...bargin! So in the mean time I thought I would pull my turbo off to check if I had cracks in the exhaust housing due to bolts working their way out. I've taken it off and bolted it to a work bench and removed all the bolts except those at the oil return which can't come out with out fouling.Now how the hell do you get the housing loose??? Ive tried twisting the center assembly from the compressor end, carefully giving it a little tap with a rubber mallet but the thing wont budge. Any suggestions?Also I'm thinking its worth doing the port flapper and actuator mod, who is the people to see about this? Link to comment https://www.fordxr6turbo.com/forum/topic/62744-help-lost-all-oil-pressure/page/4/#findComment-952825 Share on other sites More sharing options...
Guest EGOXRT Guests Posted 11/11/09 08:31 AM Share Posted 11/11/09 08:31 AM (edited) Did you put an oil pressure gauge on it? Hope it isn't a faulty sender. Edited 11/11/09 08:33 AM by EGOXRT Link to comment https://www.fordxr6turbo.com/forum/topic/62744-help-lost-all-oil-pressure/page/4/#findComment-952851 Share on other sites More sharing options...
baf6 Member 139 Member For: 16y 2m 11d Posted 11/11/09 08:35 AM Share Posted 11/11/09 08:35 AM hey im at pretty much the same stage with mine this treads been alot of help a saved me starting a new onejust got my turbo, intake and sh*t off today plan to pull the engine out on the weekendnot sure if I gonna go a rebuild or just replace the oil pump, been reading around a bit and seen quite a few ppl getting away with just doin the pump, but I'll see when I get the engine out and crack it open Link to comment https://www.fordxr6turbo.com/forum/topic/62744-help-lost-all-oil-pressure/page/4/#findComment-952853 Share on other sites More sharing options...
RUS531 RUS531 Donating Members 410 Member For: 18y 10m 9d Gender: Male Location: Emerald QLD Posted 11/11/09 09:06 AM Author Share Posted 11/11/09 09:06 AM On 11/11/2009 at 8:31 AM, EGOXRT said: Did you put an oil pressure gauge on it? Hope it isn't a faulty sender.No as both my oil pressure sender to the ecu and sender to my electronic gauge are in the same position it would be pretty unlikely that both of them failed at once, and as mentioned before there was a sound in the front of the timing case like gears not meshing properly. Brad from atomic said he as seen a few that have just damaged the inner rotor gear, which could mean for me a rebuilt pump instead of a new one.Basically I want something that will pull 400rwkw (give or take) every day comfortably, so I think I will be getting the girdle as well and by looking through threads I will need to do something with the waste gate.The other thing limiting me will be the clutch which will be done at a later stage.On another note I can't speak highly enough of brad and his willingness to help and answer my questions each time I've called. Link to comment https://www.fordxr6turbo.com/forum/topic/62744-help-lost-all-oil-pressure/page/4/#findComment-952863 Share on other sites More sharing options...
mattyb Donating Members 1,097 Member For: 17y 15d Gender: Male Location: Gold Coast, QLD Posted 11/11/09 11:14 AM Share Posted 11/11/09 11:14 AM Cam, if you need me to crack test your turbo housing let me know, it'll only take a couple of minutes... takes longer cleaning the paint off it after testing it than it does carrying out the test. Link to comment https://www.fordxr6turbo.com/forum/topic/62744-help-lost-all-oil-pressure/page/4/#findComment-952937 Share on other sites More sharing options...
RUS531 RUS531 Donating Members 410 Member For: 18y 10m 9d Gender: Male Location: Emerald QLD Posted 11/11/09 01:06 PM Author Share Posted 11/11/09 01:06 PM thanks matty! sounds like a plan.....if I can get this housing off... any ideas people? Link to comment https://www.fordxr6turbo.com/forum/topic/62744-help-lost-all-oil-pressure/page/4/#findComment-953004 Share on other sites More sharing options...
