Stock Crossover Mounts Broken
bad inferno
  • Member For: 19y 7m 21d
I just noticed that my stock plenum is just sitting on the rocker cover held by the piping. The two rubber mounting posts that I can see are broken in the middle and there is no screw on the rear mount (don't know if that one is broken as well.
Are these mounts easily broken or common to fail. Is it easy to replace them ?
thanks
  • Member For: 18y 10m 9d
I'll assume you mean the cross over and then yes it is common for them to break or be broken, they are available from ford for maybe $10-15 each and if you have an end missing you will need the nut as well.
Good luck trying to explain to the parts person what you want, It took me a five calls the first time we ordered some.
  • Member For: 17y 4m 12d
Mine disintegrated recently as well I noticed (crossover bump stops). Haven't bothered to replace them though. Is that a bad thing? It doesn't SEEM mission critical, but I'm not an expert.
I'll check mine in that case...I think one is left, if my memory is correct and there's 3! Thanks ratter.
Checked, all three of mine are kaput, and my TB join was half off! Turns out the clamp was loose as, probably my fault from a couple weeks back when I cleaned the TB. Still...need replacement bump stops! Or better yet a more permanent fix. Cheers :)
  • Talks Cheap, Let's Race
  • Member For: 18y 4m 21d
just picked up 2 of these rubber mounts and the nuts on top of them and the dealer tried to charge me $52 for the lot. talked him down to a reasonable price thou at about $36 for the lot.
I think over $20 for all three is a rort! $50 is just insane.
More reason for me to do away with the damn thing and get a better, shorter intake and intercooler system installed!
