Boost & Oil Press Sensors
BFXR6T.ute
  • Member For: 15y 4m 9d
Hi,
Does any one know where I can buy boost & oil pressure sensors and where to install them. I've got the pod, gauges & harness (all genune FPV). BF XR6 turbo.
Thanks
I think for the price you will pay for the 2 sender units to suit the genuine Ford guages you can go buy 2 Autometer cobalt guages which come with the senders to suit and put them in your pod. The genuine Ford guages are sh*te anyway. As for where to put the senders...buy an adaptor from Bursons for the oil pressure sender which screws in to where your oil pressure switch is at the moment. Boost sender can be drilled,tapped and screwed in anywhere on the pressure side before the throttle body,depending on what piping etc you have.
Thanks, Will try ford monday. Just after factory look. Just thought, If some had upgraded to autometer gauges they would sell factory sensors.
Edited by BFXR6T.ute
