twisty1 Member 65 Member For: 16y 5m 10d Posted 02/10/09 04:53 AM Share Posted 02/10/09 04:53 AM Hey guys, Just a quick one, I'm getting a set of Nizpro Valve Springs installed some point in the very near future, do I need a tune immediatly, or am I right to drive around 'till I get my pump and injectors installed and then get the tune?Also, while I've got you, I have a Capa Flash Box that has previously been used on another car (1 life is used) am I able to use that on my car? Is there any way to tell if it's locked or not?Thanks, Michael. Link to comment Share on other sites More sharing options...
Bel@Pitlane Member 94 Member For: 15y 8m 18d Gender: Female Location: Frankston Posted 02/10/09 05:52 AM Share Posted 02/10/09 05:52 AM Your car will run fine with just a valve spring change. It will not have any ill affects on your tune. As for your flashbox, no you cannot use it on your car until it is unlocked and tunes installed to suit your car. Using somebody elses tune, even if it is a custom tune, is basically a generic tune in your car and may lead to engine damage. If we can be of any more help please let me know. Link to comment Share on other sites More sharing options...
XR6TWolf Donating Members 176 Member For: 15y 7m 18d Gender: Male Location: Wellington New Zealand Posted 03/10/09 06:16 AM Share Posted 03/10/09 06:16 AM Valve springs have no impact on tune at all. Drive it forever on a stock tune....no difference. All the uprated springs are doing is preventing high rpm float. Link to comment Share on other sites More sharing options...
twisty1 Member 65 Member For: 16y 5m 10d Posted 04/10/09 02:37 AM Author Share Posted 04/10/09 02:37 AM Your car will run fine with just a valve spring change. It will not have any ill affects on your tune. As for your flashbox, no you cannot use it on your car until it is unlocked and tunes installed to suit your car. Using somebody elses tune, even if it is a custom tune, is basically a generic tune in your car and may lead to engine damage. If we can be of any more help please let me know.Will my tuner be able to unlock it? Valve springs have no impact on tune at all. Drive it forever on a stock tune....no difference. All the uprated springs are doing is preventing high rpm float.Brilliant. Thanks heaps for that guys! Link to comment Share on other sites More sharing options...
FPV6T UNDERCOAT CRUISER!!! Donating Members 1,655 Member For: 16y 11d Gender: Male Location: brisbane Posted 04/10/09 02:50 AM Share Posted 04/10/09 02:50 AM if the flash box has been reflashed to stock then yes he should be able to unlock it.if not then it will have to be sent to capa who will then send it to the USA to be unlocked.(the bloke at capa told me this)as I now have a nice paper weight to show.(flash 1 box not returned to stock not worth sending it off!!) Link to comment Share on other sites More sharing options...
twisty1 Member 65 Member For: 16y 5m 10d Posted 06/10/09 06:23 AM Author Share Posted 06/10/09 06:23 AM if the flash box has been reflashed to stock then yes he should be able to unlock it.if not then it will have to be sent to capa who will then send it to the USA to be unlocked.(the bloke at capa told me this)as I now have a nice paper weight to show.(flash 1 box not returned to stock not worth sending it off!!)Ahhhhh. Is there a way I can tell if it's flashed back to stock before I book in my tune and drive an hour to get there(I'd prefer not to leave my car there for the tuner to tell me my box is locked)?Also, is there any way I can tell the difference between the boxes?Thanks heaps for all your help, guys. Link to comment Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 8m 1d Gender: Male Location: @ my laptop Posted 06/10/09 07:11 AM Share Posted 06/10/09 07:11 AM No way of telling until they attempt to unlock it Link to comment Share on other sites More sharing options...
