sark021 Member 38 Member For: 18y 9m 14d Gender: Male Location: Sydney Posted 19/09/09 06:00 AM Share Posted 19/09/09 06:00 AM Decided recently to continue replacing as many of the filament globes with LEDs around the car and this time got as far as the number plate lights. Bought 5 point white LEDs for this but found that the overall circumference of the globe wouldn't go into the hole of the housing which holds the T10 wedge socket in place. What to do? Could buy 10mm dia. LEDs but these are usually single point and might not have enough illumination. Anyway, after a while I thought that if I could create an access hole in the lamp housing, I could then leave the socket in place and pull out and push in globes at will. Anyways, this approached worked. Sorry if this has been dealt with before somewhere, or whether is doesn't take a genius to work this modification out, however I thought I might post some pictures in case anyone has a similar issue with getting over-sized LEDs into the number plate light housing. Used a hack saw to make the slots right down to the diffuser. Gently ripped them out with long nose pliers. Left about 10-12mm of housing in place at the socket end. Link to comment https://www.fordxr6turbo.com/forum/topic/61747-rear-led-rego-plate-lamps/ Share on other sites More sharing options...
GR8XR6 ANGEL EYES Silver Donating Members 1,683 Member For: 16y 10m 27d Gender: Male Location: SE Suburbs, Melbourne Posted 19/09/09 11:59 AM Share Posted 19/09/09 11:59 AM I was planning of inserting seperate led from other end so that I could still have normal globe aswell as other enhancement. Haven't got around to it yet though! Any pics at night before and after install? Link to comment https://www.fordxr6turbo.com/forum/topic/61747-rear-led-rego-plate-lamps/#findComment-934599 Share on other sites More sharing options...
sark021 Member 38 Member For: 18y 9m 14d Gender: Male Location: Sydney Posted 19/09/09 10:26 PM Author Share Posted 19/09/09 10:26 PM On 19/09/2009 at 11:59 AM, GR8XR6 said: I was planning of inserting seperate led from other end so that I could still have normal globe aswell as other enhancement. Haven't got around to it yet though! Any pics at night before and after install? Didn't think to get before and after shots now that you mention it, but before it was like the classic warm yellowy filament glow and now it is a cool white/blue colour which kinda looks ummm, you know....cool. I have to say that it is more obvious because I have white number plates with black lettering. Don't know how effective they are with other colour plates. Link to comment https://www.fordxr6turbo.com/forum/topic/61747-rear-led-rego-plate-lamps/#findComment-934645 Share on other sites More sharing options...
