pezzaxr6t Member 30 Member For: 16y 1m 3d Gender: Male Location: perth Posted 14/09/09 01:38 PM Share Posted 14/09/09 01:38 PM hey guys tomoro im swaping my xr boot (with spoiler) for a standard xt boot lid with no spoiler soo.. its all good just gota bolt it on and feed the wires through the boot skeleton BUT the guy im swapin boot lids with, I dont think his wiring has a lug that plugs into the spoiler light and brings on the spoiler break light. so am I right? what should I do?? I was thinkin mabey tap into his wiring and connect the lug that I dont need any more .. what do use rekon?? cheers Link to comment https://www.fordxr6turbo.com/forum/topic/61628-spoiler-light-dramas/ Share on other sites More sharing options...
J0sh Donating Members 239 Member For: 16y 4m 27d Gender: Male Location: Pertthh W.A Posted 14/09/09 01:47 PM Share Posted 14/09/09 01:47 PM He wont have a plug to plug in the spoiler light into as hes is just a XT. So the easiest way to do it would be to remove your lug (see where is connects up to in your xr6t) and trace the same brake wires in the XT and tap into hes wiring, the same way yours is done from factory. Link to comment https://www.fordxr6turbo.com/forum/topic/61628-spoiler-light-dramas/#findComment-933034 Share on other sites More sharing options...
Chich Damn You's A Sexy Chich Member 3,843 Member For: 17y 2m 16d Gender: Male Location: Your House Posted 14/09/09 09:22 PM Share Posted 14/09/09 09:22 PM his should have the lug, but it will be cable tied, or wrapped in tape out of sight, my old xt had the wiring sitting in there, so have a good hard look before you go cutting your one off... Link to comment https://www.fordxr6turbo.com/forum/topic/61628-spoiler-light-dramas/#findComment-933059 Share on other sites More sharing options...
foxtrot Member 77 Member For: 16y 6m 24d Posted 15/09/09 08:44 AM Share Posted 15/09/09 08:44 AM Hi to easy just remove rear seat then fold down backrests remove side bolsters child anchor point and the pleg on the other side and 4 small xmas tree clips, lift out rear shelf and unplug the loom just in the drivers corner, then also swap the high level brake light with the dummy one in your car ( the plug for this should be taped to the speaker wiring buy it may not have a globe socket so swap that as well ). cheers MD Link to comment https://www.fordxr6turbo.com/forum/topic/61628-spoiler-light-dramas/#findComment-933212 Share on other sites More sharing options...
Rootster Just a large member member Silver Donating Members 3,125 Member For: 16y 6m 16d Gender: Male Location: sydney Posted 15/09/09 09:01 AM Share Posted 15/09/09 09:01 AM his should have the lug, but it will be cable tied, or wrapped in tape out of sight, my old xt had the wiring sitting in there, so have a good hard look before you go cutting your one off... should have one don't think if you ordered a new XT from ford and wanted a rear spoiler they would change the harness.. Link to comment https://www.fordxr6turbo.com/forum/topic/61628-spoiler-light-dramas/#findComment-933226 Share on other sites More sharing options...
