  • Member For: 21y 5m 6d
  On 27/09/2009 at 2:22 AM, JC807 said:
do the 5000k kits run hotter? I.e. burn dust and crap into the plastic causing that dull yellow effect you see on some import headlights.(or is something else causing that?)
Actually the yellowing of headlight lenses is UV light damage. It's very bad over here with NZ's OZone damage and heap of jap imports on our roads!
https://www.fordxr6turbo.com/forum/topic/61344-hids/page/2/#findComment-937706
  • Member For: 17y 4m 2d
The yellowing of the headlights in normal use is UV damage caused by people running cheap or non "UV cut" bulbs.
If running the std halogen set up, any globes should have UV cut on the packet.
https://www.fordxr6turbo.com/forum/topic/61344-hids/page/2/#findComment-937883
