New Pb Again
dalts
  • Member For: 18y 8m 17d
went out to willowbank after fitting stronger valve springs,ute made 334rwkw on the dyno before I went and managed to run 10.72@127.38 1.61 60ft,extremely happy with the result!!unfortunatly it was my 1st run of the nite then got booted,so didnt get a chance to run when it got colder.thanks to paul and tim from elite for the great tune felt very strong!!
cheers lee
Congrats got to love consistant 10's, time to get a cage so you can have a good crack.
thanks john,yeah need to run some full slicks and race fuel aswell and see how we go!!looking forward to yours going down the track should pull some good numbers
cheers lee
  • Member For: 16y 9m 2d
Time to crank it up & get the good stuff into it!!! Mid to low 10's no worries with some good rubber & abit of go fast juice.
Yeah im getting excited, even if it doesnt do a great time it'll pull a mean skid down there. lol. Traction & townsville shouldnt be used in the same sentence, might have to head down your way if we get keen.
Edited by qik1
  • Banned
  • Member For: 15y 6m 26d
bloody hell! mid 10s pass with 334rwkw! that's awesome concidering boys with 375+rwkw struggle to break into 10s wd mate! What work is on car? histall? Full slicks? Boost? Race fuel? Well done again! :D
thanks very much,I run a powerglide so it reads low on the dyno,I run mt streets, 98 fuel,full weight minus tailgate(1950kg with me in it),factory turbo with .7 front 15psi actuator,built engine,boost runs 19psi,I do run water meth injection which helps although it shows no difference in dyno figures!the big difference was the tune it make the same power from 3500 to 7000 with no drop off!! Cheers lee
sounds like traction will be a problem for you!I was lucky the track was sticky from jamboree,so if you come down plan it after a major event!cheers lee
  • Member For: 20y 8m 17d
Well done Lee, and Pual, that's making good torque, that's a good example of why you don't get to carried away with dyno figures,
and why we like to see the track mph,
David
