6Spd Manual Inspection Plate?
nut161
  • Member For: 16y 4m 1d
hi,
ive got a weird problem with the clutch in my 327rwkw turbo ute. from what I have read the clutch isnt reliable after about the 300 mark but im pretty forgiving to it and it has done about 30-40000km on it so far. now the problem is that the clutch seems to be slipping on fastish changes but doesnt slip if I load up a high gear, when I changed the engiine oil I noticed the clutch resevoir was almost empty and topped it up. the shifting felt better but the weird slippage was there and there are no signs of leaks at all.
is there an inspection plate on these boxs to check the clutch so I can check if the slave cylinder is leaking onto the plate causing slippage?
cheers,
danny
  • Forged Member
  • Member For: 17y 9m 11d
No inspection plate bud, you basically need to take the box out to see the clutch.
There is a chance that the Slave cylinder is starting to fail too, but I would recommend an Option 3 clutch kit from Mal Wood auto as thi swill easily handle the power, but also comes with a new flywheel and Alloy Slave cylinder.
  • Member For: 16y 5m 27d
hi mate yeah if your clutch cylinder is empty I would say it is the slave cylinder has gone.. when I brought my new xr6t ute a couple years back done a slave cylinder in 4000kms.. it never leaked oil but there was nothing in the clutch cylinder.. as for the clutch as Pat said lol..
  • Forged Member
:buttrock: I've had to replace one of those, you have to take the steering column out and if you have the time you can take the pedal box out to make it easier, however I left the pedal box in and managed to sort it out.
Good luck and I hope its nothing major
