  • disgruntled member
  • Member For: 16y 11m 6d
last night after work I was driving home n decided to give it abit (as you do) and when boost came on the car started to shake n bog down like traction control was on, but it was off! Thought that is was weird n just nursed it home, took it for a drive this arvo and its still doing the same thing, I dunno what it could be but im thinking valve springs? any ideas? crybaby.gif
cheers guys
https://www.fordxr6turbo.com/forum/topic/61222-valve-springs-rooted/
woops! I forgot abuot that stuff
its a 04 ba 4speed with just over 120k on the clock no mods other than a tune
Edited by kona86
I had just over 1/3 a tank at the time, I might try changing the fuel filter on the weekend
  • Forged Member
  • Member For: 18y 2m 20d
Could also be the coils or plugs mate, check them out and remember to re-gap your plugs when you throw new ones in!
Fuel filter is a good idea if it hasn't been done before - woulod be clogged up after 120,000k's! :bowdown:
sweet as Pat! yeah I put new gapped plugs in b4 the I got the X3, yeah it will be interesting to see how dirty the fuel comes out of the filter when I pull it out lol
cheers again man
  • Member For: 19y 7m 25d
Try and get hold of a flare spanner for the fuel filter flare nuts. (I can't remember the size as it was a while ago)
It sounds like an easy job but can turn sour quickly if those stubborn nuts become rounded.
Mine were very hard to undo and I'm sure it's a common thing.
I ended up giving up first time round and then borrowing the flare spanner to make sure no damage was done. (thanks Frank)
  • Member For: 18y 6m 30d
nothing alot of WD40 can fix.. spray heaps and leave it for 5 mins.. tighten the bolts to give them some play then undo them.. that what I did and NO rounded bolts..
