T56 Oil Change
xr6t4life
  • Member For: 15y 4m 13d
I changed my tranny oil today (6spd manual), jacked up the left hand side of the car and released the drain plug on the drivers side, 4.8l on old oil came out I let it drip for a while and closed it back up then I undone the fill plug on the passengers side and filled it with 4.1L of penrite manual gear oil 70 b4 it started driping out so I closed that and took it for a spin the gear changes are 100% better but every now but when its in nutrul and the clutch is out it vibrates a little bit most likely because its 700 ml short so I jacked the car back up and looked for the reverse switch to top it up a little more but could only find 1 thing which is tight as f*** and doesnt allow much room to get a spanner in there to undo am I looking at the reverse switch or is it something else
cool bananas but that leaves another problem how do u get it off there is only 1 tool I have that will fit in there (22mm open ended spanner) but even then theres no room to turn it is it possible to pull that black peice off so I can get a ratchet on there or do I have to make do with wat room is there any sugestions on what other people have used would be great :)
I'm pretty sure you need to use ATF fluid in these boxes and not gear oil, check wilth Mal Wood they are a tremec dealer & a sponsor here.
the oil was made for t56, has it on the bottle did some reaserch on the net b4 buying it as I couldnt find where to buy tranzmax Z havent had any troubles so far working a lot better than dexron 3 garbage they put in the box, still having trouble with getting that reverse switch off will have to try tomorrow when theres a bit more light
  • Moar Powar Babeh
  • Member For: 19y 2m 6d
The rubber boot on the reverse switch can comes off. there are two push on conectors inside the boot. If you pull the boot straight off you can use a 22mm deep socket or ring spanner to remove the switch.
