seduced Need more power. Now taking donations. Member 753 Member For: 16y 1m 19d Gender: Male Posted 31/08/09 11:56 PM Share Posted 31/08/09 11:56 PM There is also a new cylinder head design for the FG, with better flow or some crap. According to a Ford expert technician, the FG engines leave the B series for dead in every area. More than just a smaller turbo. Link to comment https://www.fordxr6turbo.com/forum/topic/61125-fg-f6-vs-xr6t-difference-in-turbo/page/2/#findComment-927808 Share on other sites More sharing options...
djkice Boost Addict Member 1,273 Member For: 16y 8m 24d Gender: Male Location: Perth, W.A. Posted 01/09/09 01:18 AM Share Posted 01/09/09 01:18 AM except higher comp ratio. Link to comment https://www.fordxr6turbo.com/forum/topic/61125-fg-f6-vs-xr6t-difference-in-turbo/page/2/#findComment-927831 Share on other sites More sharing options...
Venom XR6 Member 1,460 Member For: 21y 11m 20d Location: Geelong Victoria Posted 06/09/09 04:58 AM Share Posted 06/09/09 04:58 AM 8.8 up from 8.7 is bugger all. Link to comment https://www.fordxr6turbo.com/forum/topic/61125-fg-f6-vs-xr6t-difference-in-turbo/page/2/#findComment-929784 Share on other sites More sharing options...
djkice Boost Addict Member 1,273 Member For: 16y 8m 24d Gender: Male Location: Perth, W.A. Posted 06/09/09 07:08 AM Share Posted 06/09/09 07:08 AM (edited) I thought it was higher :Smy bad it is 8.8 Edited 06/09/09 07:10 AM by djkice Link to comment https://www.fordxr6turbo.com/forum/topic/61125-fg-f6-vs-xr6t-difference-in-turbo/page/2/#findComment-929802 Share on other sites More sharing options...
2MUCHKW Member 350 Member For: 18y 11m 27d Posted 06/09/09 07:28 AM Share Posted 06/09/09 07:28 AM FG F6 has forged pistons too instead of cast pistons in the FG XR6 Turbo so you can lean on the motor allot harder!Good value those FPV F6's once you start looking hard. Link to comment https://www.fordxr6turbo.com/forum/topic/61125-fg-f6-vs-xr6t-difference-in-turbo/page/2/#findComment-929810 Share on other sites More sharing options...
djkice Boost Addict Member 1,273 Member For: 16y 8m 24d Gender: Male Location: Perth, W.A. Posted 06/09/09 08:14 AM Share Posted 06/09/09 08:14 AM apparantly need to run alot more boost threw them to acheive higher power levels due to lower comp ratio. Link to comment https://www.fordxr6turbo.com/forum/topic/61125-fg-f6-vs-xr6t-difference-in-turbo/page/2/#findComment-929830 Share on other sites More sharing options...
Venom XR6 Member 1,460 Member For: 21y 11m 20d Location: Geelong Victoria Posted 11/09/09 08:41 AM Share Posted 11/09/09 08:41 AM On 06/09/2009 at 7:28 AM, 2MUCHKW said: FG F6 has forged pistons too instead of cast pistons in the FG XR6 Turbo so you can lean on the motor allot harder!Good value those FPV F6's once you start looking hard.There not forged. They are similar to the 270 pistons but lower comp and a stronger gudgeon pin. Both made by ACL, but if they go belly up I think Mahle will supply them instead. Link to comment https://www.fordxr6turbo.com/forum/topic/61125-fg-f6-vs-xr6t-difference-in-turbo/page/2/#findComment-931926 Share on other sites More sharing options...
2MUCHKW Member 350 Member For: 18y 11m 27d Posted 12/09/09 12:14 AM Share Posted 12/09/09 12:14 AM Yep still cast pistons bloke my bad ... just been redesigned and beefed up!Extract from Nizpro forum "After having 2 spare dyno XR6T FG engine here for some time we have now stripped a brand new FG F310 F6 engine. Well Ford have redesigned the F310 piston more than likely due to durability issue at long duty cycles. The new piston is massively strong in the side skirts and has a super heavy piston pin, all of course at the expensive of added weight. A new design helps however the piston although is still heavier than the older version but only by 2 grams with a total weight of 382.5 grams vs the BF piston at 380.6 grams. The real added weight is in the piston pin. The F310 comes in at 133.5 vs 115.3 grams. The ring set is carried over from the BF. The new total piston pin and ring set is now 540 grams vs 519 for the BF. Link to comment https://www.fordxr6turbo.com/forum/topic/61125-fg-f6-vs-xr6t-difference-in-turbo/page/2/#findComment-932128 Share on other sites More sharing options...
Fastback66 Member 4 Member For: 15y 7m 1d Posted 16/09/09 05:54 AM Share Posted 16/09/09 05:54 AM (edited) On 29/08/2009 at 11:45 PM, tab said: FG F6 is the same turbo as BF (everything), FG XR is smaller.So will a turbo from an FG F6 bolt straight onto my 2003 BA XR6T? With absolutely no mods required to anything? Edited 16/09/09 05:54 AM by Fastback66 Link to comment https://www.fordxr6turbo.com/forum/topic/61125-fg-f6-vs-xr6t-difference-in-turbo/page/2/#findComment-933579 Share on other sites More sharing options...
egobff6 Member Banned 22 Member For: 15y 7m 20d Gender: Not Telling Location: rottnest iland Posted 16/09/09 06:12 AM Share Posted 16/09/09 06:12 AM On 31/08/2009 at 2:45 AM, djkice said: cost is about 1800 for compressor upgrade, machine of housing, actuator and flapper mod, not including labour to remove and return turbo back on the car.New turbo's with the new version (ported) exhaust housing can be had brand new from MTQ for them sort of dollars, meaning you would still have your stock turbo intact for when trade-in time rolls around. On 16/09/2009 at 5:54 AM, Fastback66 said: So will a turbo from an FG F6 bolt straight onto my 2003 BA XR6T? With absolutely no mods required to anything?Surely will Link to comment https://www.fordxr6turbo.com/forum/topic/61125-fg-f6-vs-xr6t-difference-in-turbo/page/2/#findComment-933584 Share on other sites More sharing options...
