  • Member For: 18y 1m 6d
You should EASILY be able to fit it behind a Monza Cooler.
You need to push the Trans Cooler RIGHT UP top underneath the black pipe in this pic.
Pic is looking from the bottom of the radiator up towards the bonnet release.
I have seen this trans cooler fitted in this location with Nizpros HUGE HUGE Intercooler fitted infront of it.
Trick is to get the intercooler as far forward as you can without it rubbing on the front bar support.
Hope that helps.
  • <put funny sh*t here>
  • Member For: 18y 5m 9d
Are the standard transmission lines in BF XR Turbos different to this?
I've looked at both ends of the radiator, and cannot find two lines running into it like in the above photos.
Someone once told me they had small external oil coolers fitted from factory, is this true?
I am not sure about the BF's but I seem to remember hearing it is on the Right Hand Rear of the engine block.
Stick your head under there and see if you can see it.
  • 2 weeks later...
I tried to find the same info but couldn't find anything.
As it doesn't use valves there shouldn't be a in & out.
All I did was made sure what went into the top of the radiator went to the top of the cooler.
Hope that helps.
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 17d
at fast idle ull feel the pipe with the hot oil rushing through it from memory its the top one but as said it dont matter
  • Member For: 17y 3m 9d
Let me just say NEVER buy a universal fitting pwr trans cooler, biggest pain in the arse, JUST buy one that suits an XR6 turbo, I took my back today cause I got the sh*ts with it.
Why didn't you just buy the one like I did that comes with the correct 3/8th fittings etc.
Any other kit will need something extra for it to fit.
