arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 5m 16d Gender: Male Location: Perth Posted 31/10/16 09:20 AM Share Posted 31/10/16 09:20 AM Pussies, try it on a territory...... BA BF piece of piss Link to comment https://www.fordxr6turbo.com/forum/topic/61088-trans-cooler-install/page/18/#findComment-1619049 Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 8y 10m 24d Gender: Not Telling Location: Radioactive wasteland Posted 31/10/16 11:45 AM Share Posted 31/10/16 11:45 AM Do I get extra points for doing it on jack stands Arron? I've already done mine just left that valve on. I'll try your suggestions. I couldn't figure out a way to get in there. Link to comment https://www.fordxr6turbo.com/forum/topic/61088-trans-cooler-install/page/18/#findComment-1619085 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 12d Gender: Male Location: Adelaide Posted 31/10/16 12:09 PM Share Posted 31/10/16 12:09 PM Fharukkk doing it on stands, I'm to old for that chit haha dem hose clamps doe ..... 1 Link to comment https://www.fordxr6turbo.com/forum/topic/61088-trans-cooler-install/page/18/#findComment-1619091 Share on other sites More sharing options...
bossmang FREAKY Donating Members 12,440 Member For: 15y 3m 18d Gender: Male Location: Melbourne Posted 01/11/16 01:16 AM Share Posted 01/11/16 01:16 AM this ^^^ Link to comment https://www.fordxr6turbo.com/forum/topic/61088-trans-cooler-install/page/18/#findComment-1619134 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 6m 20d Gender: Male Location: Perth Posted 01/11/16 01:54 AM Share Posted 01/11/16 01:54 AM +1 I even put my stands on my hoist when I need to lift them up to clean and grease them 1 Link to comment https://www.fordxr6turbo.com/forum/topic/61088-trans-cooler-install/page/18/#findComment-1619138 Share on other sites More sharing options...
Ale Member 249 Member For: 13y 7m 18d Posted 01/11/16 02:13 AM Share Posted 01/11/16 02:13 AM thanks for sharing mate, and great work going the extra step with the removal of the valve assembly. can I ask which actual cooler core you went with and how many metres of hose you used? Link to comment https://www.fordxr6turbo.com/forum/topic/61088-trans-cooler-install/page/18/#findComment-1619140 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 5m 16d Gender: Male Location: Perth Posted 01/11/16 03:02 AM Share Posted 01/11/16 03:02 AM (edited) On 10/7/2016 at 4:50 AM, JETURBO said: No all the zf input anodised fittings are 1/2 inch , the ones Rob has posted up are 3/8th I use the genuine speedflow 1/2 inch fittings You guys do realize the size of the stock heat exchanger and after market PWR oil/air cooler (oil inlet and outlet) is 7 or 8 mm. 3/8 hose is all that's needed. Edited 01/11/16 03:03 AM by arronm Link to comment https://www.fordxr6turbo.com/forum/topic/61088-trans-cooler-install/page/18/#findComment-1619146 Share on other sites More sharing options...
hawlass Silver Donating Members 1,161 Member For: 17y 5m 3d Gender: Male Location: left right out Posted 01/11/16 06:26 AM Share Posted 01/11/16 06:26 AM (edited) I think 3/8 is right on the money IF the cooler is very close to the trans. I figured with the extra distance it had to travel (added resistance on the longer hose wall ) , it made sense to have a larger cross sectional area for the fluid to flow trough, to help avoid excessive back pressure on the pump. Probably only 3mm diameter in it anyway. Ale, I used 4m of hose, but I bought a 5m length to make the flush a bit easier. The cooler is a true-cool 49418. its about 275 x 200 x 38mm. Its what my trans guy recommended and supplied. I'm aware jet and others appear to be using the 25mm thick coolers which obviously work well too. Edited 01/11/16 06:29 AM by hawlass 1 Link to comment https://www.fordxr6turbo.com/forum/topic/61088-trans-cooler-install/page/18/#findComment-1619163 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 5m 16d Gender: Male Location: Perth Posted 01/11/16 07:10 AM Share Posted 01/11/16 07:10 AM PWR are 19mm Link to comment https://www.fordxr6turbo.com/forum/topic/61088-trans-cooler-install/page/18/#findComment-1619165 Share on other sites More sharing options...
Ale Member 249 Member For: 13y 7m 18d Posted 22/04/17 02:06 AM Share Posted 22/04/17 02:06 AM On 22/02/2014 at 2:28 PM, JETURBO said: Anybody willing to confirm this cooler is the 280x255 sized core? thanx in advance Link to comment https://www.fordxr6turbo.com/forum/topic/61088-trans-cooler-install/page/18/#findComment-1637102 Share on other sites More sharing options...
