  • Member For: 19y 1m 29d
Mine is as jet posted no fan and have thrashed the sh*t out of it at QR in summer and didn't top 105 degrees. Do intend on running it next time without fog.light but no expecting much difference. Tuner also cut slots in inner wheel arch to allow more air to pass through
  • Member For: 14y 2m 23d
Good pick up PH1LLO ! Not many people care to investigate this point.
In my opinion is will affect box operation ever so slightly. Will the driver notice it ? Probably not. Will it shorten the life of the box? Maybe... But by how much is anyone's guess and pulling apart two high km boxes for comparison would be about the only way to begin to get an idea.
But my opinion is pressures under certain conditions will be different to factory with all the aftermarket lines and fittings being a different size to factory. These boxes are super sensitive to pressure changes at different temps. So it's definitely something to keep in mind.
I almost wish I had have kept it stock to see how far along it went but 2 years and 40,000ks at 300 then 380rwkw still shifts like a new one. And I run martini fluid. Will probably rebuild the box within the next 12 months as preventative maintenance and to beef it up for E85 will no doubt post up findings when its apart. Should have clocked over 150k total by then
  • 1 year later...
  • 1 year later...
  • Member For: 8y 10m 23d
  • Gender: Not Telling
z4v6M2E.jpgThese are what I used. Came in a kit from the same guy. The coolers he supply's are a touch too wide to go behind the right fog light in a BF neatly. I had to make it fit.
http://www.gumtree.com.au/s-ad/1123205746
Edited by ROB83R
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 11d
No all the zf input anodised fittings are 1/2 inch , the ones Rob has posted up are 3/8th
I use the genuine speedflow 1/2 inch fittings ;)
