  • Member For: 11y 7m 28d
that's an interesting location arronm.
Trans cooler there would be good and the amount of fluid youd save in the factory lines would probably be the same as the new cooler so it wouldnt even need more fluid...awesome idea
  • Dropping a turd
  • Member For: 17y 8m
Or put it next to the engine with a fan.
Our other engine cooler. Cooler is about 30mm thick
Edited by arronm
  • Too heavy needs boost
  • Member For: 11y 10m 21d
Have you had any trouble with stone's hitting it. Because its open with no protection. Just wondering. Mine is behind the front bar behind the horn.
  • Dropping a turd
No its a street car, doesnt go offroad. No gravel etc. that's not to say an object wont flick up and hit it. But 12k and its ok so far
  • ...JD TUNING ADELAIDE...
  • Member For: 17y 27d
No fan but done a bunch of logging before we were happy with its location, and if we weren't happy it wouldn't of happened
The fog light does a fair wack of cooling/ air flow around the globe
  On 22/02/2014 at 3:58 AM, JETURBO said:
that's a sick looking car jet. mad trans cooler to.;)
  • Member For: 14y 8m 7d
Did the same thing but on the opposite side. Figured that even if its blocked off from the foggy it will be working similar to the heat exchanger, if I do any track work the foggy will come out
