Bigkeels Throbbing Member Donating Members 594 Member For: 16y 4m 20d Gender: Male Location: Victoria Posted 05/07/12 09:20 AM Share Posted 05/07/12 09:20 AM http://www.ebay.com.au/itm/Ford-Falcon-Territory-4-6-speed-Automatic-Oil-Cooler-Bypass-Fittings-/140627057238?pt=AU_Car_Parts_Accessories&hash=item20be069a56#ht_2913wt_934are they the fittings you got chil? 1 Link to comment https://www.fordxr6turbo.com/forum/topic/61088-trans-cooler-install/page/10/#findComment-1263342 Share on other sites More sharing options...
spinr33 Donating Members 964 Member For: 13y 10m 9d Posted 05/07/12 09:21 AM Share Posted 05/07/12 09:21 AM Yes it will fit with the foam mounting system I fitted mine behind an f6 cooler it fits just !! besides what this forum said its a massive karnt.To get extra read vital room undo the radiator mounts at the top and slide it all the way back towards the engine this gets you maybe 10-20mm which you need also mounting it near the top middle seems to give you a tiny bit more room I think from memory I even had to leave the radiator mounts off refit the cooler then refit the rad mounts after the cooler is in as the cooler was fowling everything.Good luck I def wouldnt ever do it again with an f6 cooler Link to comment https://www.fordxr6turbo.com/forum/topic/61088-trans-cooler-install/page/10/#findComment-1263343 Share on other sites More sharing options...
wilba Member 828 Member For: 16y 7m 24d Gender: Male Posted 05/07/12 11:50 AM Share Posted 05/07/12 11:50 AM A few zip ties to hold it place ay Link to comment https://www.fordxr6turbo.com/forum/topic/61088-trans-cooler-install/page/10/#findComment-1263435 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 17y 26d Gender: Male Location: Adelaide Posted 05/07/12 12:20 PM Share Posted 05/07/12 12:20 PM mate BECAUSE RACE CAR lolmines been on for 6 thousand kms and if I took it off right now ud never know , no rubbing no bollocks like others are assuming its in tight as without any zip ties I put a few there to stop it maybe tilting forward under heavy braking but as I said its no going anywhere, do as ya please I want my tranny cooler up front getting all the cool air it can Link to comment https://www.fordxr6turbo.com/forum/topic/61088-trans-cooler-install/page/10/#findComment-1263454 Share on other sites More sharing options...
wilba Member 828 Member For: 16y 7m 24d Gender: Male Posted 05/07/12 09:43 PM Share Posted 05/07/12 09:43 PM Yea copy that well I think some one should make me a mounting brace for me I will pay for it -_- Link to comment https://www.fordxr6turbo.com/forum/topic/61088-trans-cooler-install/page/10/#findComment-1263531 Share on other sites More sharing options...
ljf12 Donating Members 20 Member For: 14y 5m 29d Posted 06/07/12 05:28 AM Share Posted 06/07/12 05:28 AM Thanks for the help.Maybe my inter cooler had non genuine rubber mounts (longer) as there was no way the trans cooler would fit. Ended up shortening the intercooler mounting brackets (cut and weld job) all good then. Also had to modify the horn bracket .I also found the following helpfull when fitting the intercooler with the trans cooler in place.The thread on the rubber mounts were way longer then they needed to be , cut them as short as possible where they bolt on to the brackets.Have the brackets floating around the general area (in the car!), fit the intercooler from underneath, attach it to the brackets, bolt the brackets to the car. Link to comment https://www.fordxr6turbo.com/forum/topic/61088-trans-cooler-install/page/10/#findComment-1263707 Share on other sites More sharing options...
wilba Member 828 Member For: 16y 7m 24d Gender: Male Posted 06/07/12 09:06 PM Share Posted 06/07/12 09:06 PM Would anyone have any pics of there trans cooler mounted on there fg . Or just make me the mounting brackets :-) Link to comment https://www.fordxr6turbo.com/forum/topic/61088-trans-cooler-install/page/10/#findComment-1263967 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 9m 22d Gender: Male Location: Townsville Posted 07/07/12 07:11 AM Share Posted 07/07/12 07:11 AM wilba,Have a go yourself mate, it seriously isn't that hard and you will be rapped with yourself once its done regardless of what it looks like! As long as there isn't metal on metal rubbing and its sturdy your onto a winner so have a crack at it... Link to comment https://www.fordxr6turbo.com/forum/topic/61088-trans-cooler-install/page/10/#findComment-1264104 Share on other sites More sharing options...
old_mate Member 767 Member For: 19y 4m 12d Gender: Male Location: Brisbane Posted 07/07/12 09:40 AM Share Posted 07/07/12 09:40 AM (edited) I dont have any photo's of mine, but its mounted up behind the drivers foglight. Have had slots cut out in inner guard for airflow. Couldn't fit it our front due to the Process West cooler.The installer was a little worried about airflow during summer, so we will see. Might have to get creative making air inlets in the lower grill or doing something around the fog lights.I'll get some snaps next time the front bar is off. Edited 07/07/12 09:41 AM by old_mate Link to comment https://www.fordxr6turbo.com/forum/topic/61088-trans-cooler-install/page/10/#findComment-1264133 Share on other sites More sharing options...
wilba Member 828 Member For: 16y 7m 24d Gender: Male Posted 07/07/12 10:57 AM Share Posted 07/07/12 10:57 AM Hahahha yea just dnt want to fit it to realize I carnt finish or I <3 Bananas it up Link to comment https://www.fordxr6turbo.com/forum/topic/61088-trans-cooler-install/page/10/#findComment-1264144 Share on other sites More sharing options...
