  • Member For: 16y 9m 21d
hey guys sorry if this has been covered b4 but I couldnt find exactly what I was looking 4.. anywayz im after an exhaust within the next couple weeks, just wondering if the xforce 4" dump 3.5" cat back would flow enough for 380-400rwkw, if not ill put the nizpro 4" on.. just wanna get pplz opinion's on the xforce exhaust, can they flow enough or better go the 4"?
Thanks guys..
https://www.fordxr6turbo.com/forum/topic/61037-380-400rwkw/
  • No V6 for me thanks!!
  • Member For: 19y 9m
I think Xforce is doing a 4" system aswell. Xforse gear is 2nd to none & all Nizpro gear is well refined .. I you go the 4" you will be ready for the 500+ rwkw.
Both with get you what.
Muzza
https://www.fordxr6turbo.com/forum/topic/61037-380-400rwkw/#findComment-925912
  • Member For: 16y 11m 25d
xforce only do a 4' to suite the fg's & wont be doin one according to a little birdy. The 3 1/2 system will easily flow 400kw. I'm not overly happy with the note that it gives at full noise but I had a custom rear section made up & now it flows great & sounds even better.
https://www.fordxr6turbo.com/forum/topic/61037-380-400rwkw/#findComment-928434
On the fg's it is. I dont know of anyone running a 4' system in a ba-bf without running big power so the problem never really came up I spose. Most of us went a hiflow cat on the factory system & when ya wanted over 330 & intended to push it hard you went the 3 1/2 or 4' so the issue of keeping boost down didnt come up. Could be wrong but that's my thought???
https://www.fordxr6turbo.com/forum/topic/61037-380-400rwkw/#findComment-928507
  • Member For: 16y 3m 16d
Why is everyones preferred option an off the shelf system??? I went with a custom system, 3.5inch with 4inch split dump in stainless. Was $2,500, but it sounds and in my opinion performs better then any X Force system ive ever heard.
https://www.fordxr6turbo.com/forum/topic/61037-380-400rwkw/#findComment-928667
thanks 4 the replies, most likely ill stick with the 3.5" system as I dont intend 2 go over the 400rwkw mark. the waste gate has been done so shouldnt have any boosting problems, also the rear section actually goes in2 twin 2.5" not sure if that makes any difference.
thanks heaps
https://www.fordxr6turbo.com/forum/topic/61037-380-400rwkw/#findComment-928825
  • Banned
  • Member For: 15y 10m 24d
I've found that my XFORCE 3.5" System has found its limit at about 360-380rkw. Still not but for a chinese off the shelf system supporting about 600 flywheel HP in my opinion. It has saved me from squeezing more power out of the stock internals.lol.
https://www.fordxr6turbo.com/forum/topic/61037-380-400rwkw/#findComment-928917
