Benny Member 1,869 Member For: 21y 10m 18d Gender: Male Location: Newcastle Posted 26/08/09 05:25 AM Share Posted 26/08/09 05:25 AM All,Just thought I'd write a quick post about my most recent issue. The last week or two I had noticed a strange noise coming from the rear off my car when it was cold and only at low speed. Kind of sounded like a tyre rubbing on an inner plastic guard but not continuously, just now and then. I thought this was strange and decided I needed to do some investigation to make sure my wheel wasn't going to fall off or something. So I jacked the car up and had a look around checking that nothing was rubbing or looking like it was about to become dislodged. Also checked my coilovers, suspension bolts and calipers but couldn't find anything. So I lowered the car abck down and went for a test drive. Same issue was still there.So back in the garage and up onto the jack again. This time both rear wheels off, calipers removed and rotors as well. After the left rear caliper was removed the issue became clear. I had considerable slop on the left rear hub assembly compared to the right rear. After a bit more investifgation I came to the assumption that the left rear wheel bearing had failed. Now I'm no mechanic so it was off to Ford to get them to inspect and make the decision.To cut a long story short after going to Ford the left rear wheel bearing had failed. This resulted in considerable slop in the rear hub assembly. The bearing was replaced and also the stub axle as the inner bearing race was seized on the stub.Can't say I'm impressed with this failure but the service from Ford was excellent and no hassles with replacing the faulty parts.Thought this might be worth mentioning and assist others when inspecting their cars.Benny Link to comment https://www.fordxr6turbo.com/forum/topic/61012-fg-turbo-wheel-bearing-failure/ Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 17y 5d Gender: Male Location: Earth Posted 26/08/09 07:02 AM Share Posted 26/08/09 07:02 AM Bugger. Lucky you caught it early before it lunched itslf. Link to comment https://www.fordxr6turbo.com/forum/topic/61012-fg-turbo-wheel-bearing-failure/#findComment-925258 Share on other sites More sharing options...
Erko Donating Members 1,079 Member For: 21y 8m 22d Gender: Male Location: Sydney Posted 26/08/09 07:15 AM Share Posted 26/08/09 07:15 AM yep...pretty ordinary. I've had rear axle bearing failure LHS just recently, and looks like it is playing up again........so will probably go back in again next week. What a nugget ! Link to comment https://www.fordxr6turbo.com/forum/topic/61012-fg-turbo-wheel-bearing-failure/#findComment-925262 Share on other sites More sharing options...
fluke Member 32 Member For: 15y 10m 17d Gender: Male Posted 26/08/09 07:52 AM Share Posted 26/08/09 07:52 AM Hi, could you tell which side it was from just driving it, I think I may have a similar prob with my BA rear left, got a strange rub noise that increases with speed and sometimes dissappears on corners etc. Link to comment https://www.fordxr6turbo.com/forum/topic/61012-fg-turbo-wheel-bearing-failure/#findComment-925296 Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 10m 18d Gender: Male Location: Newcastle Posted 26/08/09 09:51 AM Author Share Posted 26/08/09 09:51 AM Fluke,I couldn't be sure what side when driving around but I was suspecting possibly the left from the noises in the car. If you wanna check just jack the car up and see if there is any slop when you riggle the wheel left and right with your hands.Regards,Benny Link to comment https://www.fordxr6turbo.com/forum/topic/61012-fg-turbo-wheel-bearing-failure/#findComment-925420 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 19y 1m 4d Gender: Male Location: Sydney NSW Posted 26/08/09 11:58 AM Share Posted 26/08/09 11:58 AM How many kays you racked up Benny?My BA ate the same bearing, but at 90ooo kays Link to comment https://www.fordxr6turbo.com/forum/topic/61012-fg-turbo-wheel-bearing-failure/#findComment-925514 Share on other sites More sharing options...
fluke Member 32 Member For: 15y 10m 17d Gender: Male Posted 26/08/09 01:01 PM Share Posted 26/08/09 01:01 PM Cool, will do that and check it out, thanks Link to comment https://www.fordxr6turbo.com/forum/topic/61012-fg-turbo-wheel-bearing-failure/#findComment-925546 Share on other sites More sharing options...
Benny Member 1,869 Member For: 21y 10m 18d Gender: Male Location: Newcastle Posted 27/08/09 02:34 AM Author Share Posted 27/08/09 02:34 AM RAP1D said: How many kays you racked up Benny?My BA ate the same bearing, but at 90ooo kaysChris,17000k's so far. Would have thought they'd last longer than that. Diff bush is going to need changing soon also from looking at it.Benny Link to comment https://www.fordxr6turbo.com/forum/topic/61012-fg-turbo-wheel-bearing-failure/#findComment-925694 Share on other sites More sharing options...
bentles Member 121 Member For: 16y 8m 26d Gender: Male Location: melbourne Posted 27/08/09 09:38 PM Share Posted 27/08/09 09:38 PM fluke,if its disapearing on corners its most likley a wheel bearing... if its rear left should go away when you turn left as you are taking the weight off that wheel, turn right and it should get louder..... same story with front wheel bearings if its right front if you turn right that wheel has less weight and the noise goes away... turn left and it should get worse... Link to comment https://www.fordxr6turbo.com/forum/topic/61012-fg-turbo-wheel-bearing-failure/#findComment-926097 Share on other sites More sharing options...
Erko Donating Members 1,079 Member For: 21y 8m 22d Gender: Male Location: Sydney Posted 13/10/09 12:27 AM Share Posted 13/10/09 12:27 AM mines back in to re do the bearing again......seems it wasnt done right and its collapsed again. happy dayz! Link to comment https://www.fordxr6turbo.com/forum/topic/61012-fg-turbo-wheel-bearing-failure/#findComment-942560 Share on other sites More sharing options...
