  • Member For: 16y 8m 19d
Hey guy's just wondering if anybody has had the same problem as me. I own a 03 BA XR6T I was driving down the M2 today and car sounded like it has a exaust leak (Aftermarket full system)
and then I realised when it come's on boost it's not responding but is still spooling up, the car is still to hot to check but could it be turbo gasket or exuast gasket or even worse f*cked turbo???
https://www.fordxr6turbo.com/forum/topic/60832-help-with-car/
  • Forged Member
  • Member For: 18y 3m 3d
Could've lost a bolt out of the turbo too mate, check the ones that bolt into the rear housing - does it sound like a tractor or is it only a quiet leak?
  • Banned
  • Member For: 15y 10m 29d
Your manifold bolts could be loose. When I pulled my turbo off they dont run a gasket fro the manifold to the turbo. Just pull off all your heatshields and take a look. You should be able to spot the leak then.
  • 3 weeks later...
  • Member For: 15y 11m 19d
could be as the guys said a bolts come loose and leaking pressure
  • Member For: 17y 27d
Happens all the time make sure you check all the bolts. I didn't check mine for a while and it ruined the gasket around the turbo to dump pipe :(
