noxid Inactive Members 1 Member For: 15y 4m 19d Posted 19/08/09 01:04 AM Share Posted 19/08/09 01:04 AM I have a BA MKII XR6 Turbo ute which I have lowered and have found they are hitting my chassis. has anyone had this problem or herd of it? Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 21y 3m 16d Gender: Male Location: Perth, WA Posted 19/08/09 01:30 AM Share Posted 19/08/09 01:30 AM Mate, those pictures are as clear as mud Where is the spring hitting? The springs are under the diff, so if anything the top of the diff housing could be hitting the chassis? But if this was the case it would be hitting the bump stops before anything else. Link to comment Share on other sites More sharing options...
Adrian6T T.P.I.S. Donating Members 2,578 Member For: 20y 1m 4d Gender: Male Location: SoR, WA Posted 19/08/09 01:40 AM Share Posted 19/08/09 01:40 AM Hi mate,Mine does the same (alto less then yours but similar). It is at the inside front of the springs they rub the chassis rails. Link to comment Share on other sites More sharing options...
workxr6 Member 28 Member For: 15y 6m 13d Gender: Male Location: Brisbane Southside Posted 19/08/09 12:23 PM Share Posted 19/08/09 12:23 PM I take it that's from some hard cornering or the front bush is cactus. Is a Speed Pro or equivalent bush available to reduce the movement? Link to comment Share on other sites More sharing options...
Adrian6T T.P.I.S. Donating Members 2,578 Member For: 20y 1m 4d Gender: Male Location: SoR, WA Posted 19/08/09 02:34 PM Share Posted 19/08/09 02:34 PM I take it that's from some hard cornering or the front bush is cactus. Is a Speed Pro or equivalent bush available to reduce the movement?Probably hard cornering or the torque. I first noticed it at 8000km so I dont think its wear. Link to comment Share on other sites More sharing options...
