Coates Rotary Valve Engine Concept
NB4C
  • Member For: 16y 1m 23d
Link, if you want to do more reading: http://www.coatesengine.com/technology-document.html
The idea is basically replacing the poppet valve seen in most engine with a rotary valve. Seems like a very clever and interesting idea which I think is worth sharing. But I do wonder why this tech isn't mainstream yet, it's been around for a few decades.
How it works:
Rotary Valve Engine
vs
Standard Poppet Valve Engine
Advantages summary:
> Peformance: more torque and power
> Efficiency: 35-40% thermal efficiency vs. 25% in most modern engines
> High compression ratios: by easing the hot spots on exhaust valves and increasing the threshold for detonation/ping
> More durable and reliable valves
> Simpler/less parts: no poppet valves, no springs, no cams
> Valve float eliminated: higher RPMs possible
> Less emissions
> Less noise/vibration due to the non reciprocating valves
> Potentially cheaper
(Brief overview video. Ignore the Greeny references.)
Comments ?
Edited by NB4C
  • New Member
  • Member For: 22y 4m 12d
The "Dean rotary valve" (Australian design) worked on a similar principal , saw a demonstation of the "rotary valve" in operation in the early seventies - the father & son team had very little money to develop their idea further , I heard that they had a meeting with "Ralph Sarich" in the early seventies and never heard anything again - the "Dean Rotary valve" was actually a drum that revolved above the cylinder head and replace all the valve gear with ports for the incoming fuel = it worked something like a "rotary valve" in early Kawasaki two stroke motorcycle engines; from memory a major problem they had was with seals or seal designs - what I saw did work and seemed like a good idea , it was attached to a late sixties six cylinder Falcon engine .
  • Member For: 17y 10m 21d
I like it, just not sure about the durability of the seals especially as there is no oil lubrication in the head. Would love to see one in action though and see the durability and efficiency testing be done by a third party.
Definitely sounds interesting and if their claims are correct I hope someone puts it in to production.
