How Do I Turn The Alarm Off?
bullet1
  • Member For: 21y 4m 17d
ive had the same problem n have never been able 2 turn it off.
QUOTE (RAPHOON @ Aug 18 2009, 08:59 AM)
I believe that the alarm will not go off if you have your ignition switched to the "ON" position prior to disconnecting the terminal.
will this still work if u have a tracker alarm on the car? ive been told by fpv I cannot turn this off,my battery always goes dead because I never drive it,its a pain in the arse when NRMA come n the alarms going nuts while they change the battery. and help???
I don't know if this will work on an aftermarket alarm system. The installer/supplier should be able to provide you with the correct rpocedure.
  • Member For: 17y 1m 17d
I had this issue on the weekend, and I got told to have ignition in ON, then disconnect +VE terminal on battery.
Alarm went off when I did it that way.
Left ignition in ON, with battery connected, and just unplugged the siren itself, and that worked.
Yet a mate with a Force6 tried the method that worked for me, and the alarm went off.
He'd also previously tried ignition ON then disconnect -VE on battery, which also set the alarm off.
I am utterly confused as to what the correct procedure is, but hopefully one works for you.
  • Member For: 15y 8m 22d
I did what you said. I turned the ignition to on, then disconnected the negative terminal. The alarm didn't go off! When I reconnected the battery, I didn't have the key in the ignition at all. On reconnection, the alarm gave 1 chip which is the unlock confirmation tone in my case. Everything works as normal so a big thanks to all you guys that came through with the answer to my question.
Bullet1
