bullet1 Member 10 Member For: 15y 10m Gender: Male Location: Sydney Posted 17/08/09 08:06 PM Share Posted 17/08/09 08:06 PM Hi everyone,I've got an 07' R Spec and every time I disconnect the battery the alarm goes off. Is there a sequence to turn it off? I read in the owners manual if you turn the key from Acc to On 10 times, it disables the alarm but it doesn't say how to re-enable it. There is no key to switch it off. I've unlocked the car then tried pressing the unlock button on the remote after disconnecting the battery while it's going off but no good. Does anyone know the trick?Cheers,Bullet1 Link to comment Share on other sites More sharing options...
Mike XR6T iTs alL DaRDy........ Donating Members 780 Member For: 17y 3m 17d Gender: Male Location: Adelaide Posted 17/08/09 08:23 PM Share Posted 17/08/09 08:23 PM the siren should have a small key that goes in it and turns it off. wont disable the alarm just turns siren off for changing batteries etc Link to comment Share on other sites More sharing options...
AGENT ORANGE F6 Phoon ----- MISH!! Member 348 Member For: 17y 10m 1d Gender: Male Location: BRISBANE Posted 17/08/09 11:09 PM Share Posted 17/08/09 11:09 PM Negative on the key I don't know anyone that has one an I've been to fpv before in search of one no part number best advice from senna was stick a cloth in it or turn car to first click so radio is on an disconnect apparently it doesn't go off Link to comment Share on other sites More sharing options...
RAPHOON Donating Members 1,776 Member For: 21y 5m 25d Posted 17/08/09 11:29 PM Share Posted 17/08/09 11:29 PM (edited) I believe that the alarm will not go off if you have your ignition switched to the "ON" position prior to disconnecting the terminal. Edited 17/08/09 11:29 PM by RAPHOON Link to comment Share on other sites More sharing options...
Adrian_F6 Large Member Member 551 Member For: 16y 3m 16d Gender: Male Location: In The Sticks Posted 18/08/09 02:30 AM Share Posted 18/08/09 02:30 AM I believe that the alarm will not go off if you have your ignition switched to the "ON" position prior to disconnecting the terminal.correct. Link to comment Share on other sites More sharing options...
Adrian6T T.P.I.S. Donating Members 2,578 Member For: 20y 19d Gender: Male Location: SoR, WA Posted 18/08/09 02:34 AM Share Posted 18/08/09 02:34 AM Correct. Turn your key on until lights are on your dash, then disconnect the battery. Leave the key where it is until you reconnect the battery then turn the key off. Link to comment Share on other sites More sharing options...
bullet1 Member 10 Member For: 15y 10m Gender: Male Location: Sydney Posted 18/08/09 08:14 AM Author Share Posted 18/08/09 08:14 AM Thanks a lot guys. I even rang FPV road side assist and they told me to disconnect the battery then push the unlock button on the remote. That didn't work. Having the key switched to "On" then disconnecting the battery makes sense. I'll try that an Saturday when I've got some time and come back with the results.Thanks again for all your help,Bullet1 Link to comment Share on other sites More sharing options...
TORN8O Member 120 Member For: 17y 7m 1d Gender: Male Location: sydney Posted 18/08/09 08:26 AM Share Posted 18/08/09 08:26 AM ive had the same problem n have never been able 2 turn it off. QUOTE (RAPHOON @ Aug 18 2009, 08:59 AM) I believe that the alarm will not go off if you have your ignition switched to the "ON" position prior to disconnecting the terminal. will this still work if u have a tracker alarm on the car? ive been told by fpv I cannot turn this off,my battery always goes dead because I never drive it,its a pain in the arse when NRMA come n the alarms going nuts while they change the battery. and help??? Link to comment Share on other sites More sharing options...
NFORCD Force Fed Fords Member 209 Member For: 16y 2m 11d Gender: Male Location: Melbourne Posted 18/08/09 08:47 AM Share Posted 18/08/09 08:47 AM As the members stated above, ignition on than disconnect... The alarm wont go off than.... Link to comment Share on other sites More sharing options...
smicky Go Pies!!! Donating Members 2,852 Member For: 16y 10m 5d Gender: Male Location: Vic Somewhere - Sometimes NSW Posted 18/08/09 02:20 PM Share Posted 18/08/09 02:20 PM Rip out the POS alarm and get a real one!Something with a key switch function at least! Link to comment Share on other sites More sharing options...
