GMH8R Donating Members 110 Member For: 16y 10m 1d Gender: Male Location: Mt Isa Posted 16/08/09 06:09 AM Share Posted 16/08/09 06:09 AM (edited) Hey guy's I'd like to get some opinoins on what damage my motor may have had with the news I got today. I have been taking my fg xr6t ute to a workshop for servicing and today found out that the oil that has been put in my ute for the past 18 000k's is 5w 30 oil. I give it a good squirt most time's I drive it once or twice and did my first gamy little burnout in 6 months last night. And when I asked him why did you guy's put that oil in when the manual says 15w 40 he said It doesn't matter what oil you use as long as it has oil in it. And yes I'm serious A trade qualified mechanic told me those words. time to change who services my ute. Edited 16/08/09 06:20 AM by GMH8R Link to comment https://www.fordxr6turbo.com/forum/topic/60673-oils-aint-oils/ Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 10m 28d Gender: Male Location: The 8th Dimension Posted 16/08/09 06:14 AM Share Posted 16/08/09 06:14 AM While the oil is not quite the right spec, 10W40 is usually what people run; if it was a good syth or semi-syth I don't think you would have caused much damage. Link to comment https://www.fordxr6turbo.com/forum/topic/60673-oils-aint-oils/#findComment-921140 Share on other sites More sharing options...
mntxr Member 45 Member For: 16y 2m 28d Gender: Male Location: melbourne Posted 16/08/09 06:54 AM Share Posted 16/08/09 06:54 AM what I can find out of the castrol trade section is that they recommend a 10w 40 semi senthic but will look at work on monday to make sure Link to comment https://www.fordxr6turbo.com/forum/topic/60673-oils-aint-oils/#findComment-921150 Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 1m 10d Gender: Male Location: Brisbane Posted 16/08/09 07:32 AM Share Posted 16/08/09 07:32 AM Sounds like quite a knowledgeable bloke Unlikely to cause damage under normal operating conditions but with so much to choose from why would you put the wrong oil in? :o Link to comment https://www.fordxr6turbo.com/forum/topic/60673-oils-aint-oils/#findComment-921167 Share on other sites More sharing options...
GMH8R Donating Members 110 Member For: 16y 10m 1d Gender: Male Location: Mt Isa Posted 16/08/09 08:32 AM Author Share Posted 16/08/09 08:32 AM Yeah I found it hard to believe myself. Am glad I found this out before I get my tune done, as I would be more concerned if I had say 320rwkw and find out it has been using the wrong spec oil. :o Link to comment https://www.fordxr6turbo.com/forum/topic/60673-oils-aint-oils/#findComment-921185 Share on other sites More sharing options...
freeze_dk I am dissatisfied with my current employment situation Donating Members 8,610 Member For: 18y 8m 7d Gender: Male Posted 16/08/09 08:48 AM Share Posted 16/08/09 08:48 AM So to him it wouldnt matter if you used Extra Virgin Olive Oil?.. It's oil isnt it.. time to find a new workshop Link to comment https://www.fordxr6turbo.com/forum/topic/60673-oils-aint-oils/#findComment-921195 Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 11m 15d Gender: Male Location: Earth Posted 16/08/09 10:53 AM Share Posted 16/08/09 10:53 AM Name and shame time. Link to comment https://www.fordxr6turbo.com/forum/topic/60673-oils-aint-oils/#findComment-921246 Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 10m 28d Gender: Male Location: The 8th Dimension Posted 16/08/09 10:56 AM Share Posted 16/08/09 10:56 AM that's not going to fly, if you have a burning need to find out who the company in question is give GMH8R a PM; other wise the name is not to be mentioned in this thread.If you need clarification on why please read the forum Rules and pay close attention to rule 2 Link to comment https://www.fordxr6turbo.com/forum/topic/60673-oils-aint-oils/#findComment-921248 Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 3m 21d Gender: Male Location: Sydney Posted 16/08/09 10:59 AM Share Posted 16/08/09 10:59 AM Sounds like a lazy old school mechanic that has failed to understand modern cars.While he is technically right about the oil it would depend on what oil you have been running for the past 18k km.If it has been a good quality synthetic oil, then you will be fine and there should be no damage.However, I would find a workshop that has better attention to detail. Link to comment https://www.fordxr6turbo.com/forum/topic/60673-oils-aint-oils/#findComment-921250 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 8m 12d Gender: Male Location: Perth Posted 16/08/09 11:03 AM Share Posted 16/08/09 11:03 AM i have been running 5w30 for over 2 years in my car running between 330 and 350rwkw, i have some very expensive bits going around and around in my engine and have ABSOLUTLTY no adverse affects from the 5w30. Granted mine is fully synthetic but i don't think the oil is a problemTechnically you mechanic is correct, most modern semi synthetics wont hurt a modern engine ( the first sign of an oil pressure issue the car would have let you know), don't forget the ford interval is 15000km's. If you are running shorter intervals and running a higher quality oil than the crap ford use, you will be fine.I think his attitude is a good reason to move on tho..... Link to comment https://www.fordxr6turbo.com/forum/topic/60673-oils-aint-oils/#findComment-921254 Share on other sites More sharing options...
