alexfinch89 Member 6 Member For: 15y 11m 5d Posted 12/08/09 08:32 AM Share Posted 12/08/09 08:32 AM Hi guys,For quite some time now I hav been having this problem in which ill be slowing down at the lights for instance and in the last 0-10km/h b4 I stop I can hear this loud humming noise from the brake and the brake pedal vibrates under my foot, my brake pads are fine also discs have been skimmed so all in all the brakes work fine apart from this!, its almost like ABS is kicking in but no light comes on or anything?? Any help would be greatly appreciated as this problem is really annoying me and nothing worse than having a passenger in the car ask wats that noise and u cant explain it :(Thank you in advance! Link to comment Share on other sites More sharing options...
Rootster Just a large member member Silver Donating Members 3,125 Member For: 16y 1m 18d Gender: Male Location: sydney Posted 12/08/09 08:39 AM Share Posted 12/08/09 08:39 AM well going by what you said that the braking system is fine(vibrates under foot it could only be disc's) :hiwelcome: .....could be a road noise from the tyres.... Link to comment Share on other sites More sharing options...
alexfinch89 Member 6 Member For: 15y 11m 5d Posted 12/08/09 08:44 AM Author Share Posted 12/08/09 08:44 AM Only thing is the there is no vibration at all at any speed, braking is really smooth up until that last little bit, in which car is pretty much stopped then it does it but it only lasts for about 2-3 seconds, could it be something to do with ABS kicking in due to fauly wire on dirty solenoid etc? Link to comment Share on other sites More sharing options...
Rootster Just a large member member Silver Donating Members 3,125 Member For: 16y 1m 18d Gender: Male Location: sydney Posted 12/08/09 08:55 AM Share Posted 12/08/09 08:55 AM mate only guessing but mine does the same...it's more of a worn shock/strut feel..like it knocks sometimes.....and a little more pedal pressure is need ... Link to comment Share on other sites More sharing options...
Ford powa Member 111 Member For: 16y 4m 2d Gender: Male Location: North West Aus Posted 25/08/09 03:26 PM Share Posted 25/08/09 03:26 PM got the same problem on my BA too alexfinch89. all the same just for me the ABS sign is always on, and T/C is always off. (lights light up). im gonna get it checked out. Link to comment Share on other sites More sharing options...
GNU UP Member 124 Member For: 15y 3m 9d Gender: Male Location: sydney south Posted 08/04/10 01:44 PM Share Posted 08/04/10 01:44 PM I got the same problem ford power... I got told it was cause I put 20's on and lowered springs, although I still have problem now with 18's on..let us know how u go? I find switching car off then on clears it but as soon as u go full lock its back again, I also have abs shudder at low speed Link to comment Share on other sites More sharing options...
_Spin_ Donating Members 695 Member For: 16y 9m 29d Posted 08/04/10 04:45 PM Share Posted 08/04/10 04:45 PM (edited) ABS and TC lights on could be a dirty ABS sensor. Have you had your Rotors machined on car ie: with the rotors not removed?My car will illuminate both lights but if turn the car off and hold my tongue right a few seconds later when I restart its all good.Then it won`t do it for ages or do it a few more times that day. Brakes feel awesome with the ABS inactive, I actually don`t like feel of the ABS. Its ghey and intrusive.A brake expert told me that the ABS in these cars isn`t all it should be or could be. Edited 08/04/10 04:46 PM by _Spin_ Link to comment Share on other sites More sharing options...
Guest XR09 Guests Posted 09/04/10 02:47 AM Share Posted 09/04/10 02:47 AM 1. Rotor grind on car. The usual suspect.2. Pad pins...... Make sure they are strait and tight.3. Upper control arm bushes.... Go super Pro and fit 2mm washers either side of the new bushes.4. Rust on hub or inside rotor housing..... Get some emery and clean it off. Spray carefully with an anti corrosive. Link to comment Share on other sites More sharing options...
dashturbo Donating Members 280 Member For: 16y 3m 26d Gender: Male Location: Watsonia Posted 09/04/10 05:14 AM Share Posted 09/04/10 05:14 AM Cheapo Pads? glazed discs? Did you get all four discs 'skimmed'?Sounds like there is a vibration between the pad and the disc, could be from incorrectly installed pads or a sharp leading edge? maybe put in backwards? or Left Right mixed up?Other option is ABS, but you would expect the light on, have you got the same size wheels and tyres front and back? does the light come on if you set off the abs otherwise? Link to comment Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 14y 10m 16d Gender: Male Location: Christchurch, New Zealand Posted 09/04/10 09:14 AM Share Posted 09/04/10 09:14 AM The ABS light should only come on if the system has a fault. I have driven a car once that had an issue in the low speed part of stopping and would activate the ABS for no reason. This would vibrate the pedal while it was doing its ABS thing. It was very annoying and dont know what caused it. Link to comment Share on other sites More sharing options...
