  • Member For: 16y 8m 28d
I know I didnt damage any earth straps when I serviced it....
I might have to clean the throttle body....
I went to herrod a while ago and they said that the throttle body might need changing....but I looked at the bloke strangly.....cause I didnt think that it would have to go that far!!!
if I take it to a tuner.....do I have to get a CAPA flash tuner to diagnose the problems or can I just get an edit to try and find them???
  • Replies 40
  • Hey guys, Tab is here... Oh i feel sick
  • Member For: 16y 11m 18d
you can chuck it on a dyno and check whats happening, but you will need to get a flash box to tune it
throttle position sensor, its on the side of the throttle body
  • 570Nm @1800rpm
  • Member For: 21y 7m 19d
Throttle Position Sensor. I am 99.9% sure that they are all the same. One of a normal BA should be fine for you to test.
Edited by XtRmn8
id try get one off a car that is running good so you know that the tps is good, if you get one from the wreckers it could be faulty
  • 570Nm @1800rpm
I am pretty sure I have seen them on ebay for about $45 for a new one. But like vixen said borrow one from a BA that is running fine and see if that fixes your problem first.
