trevs Member 781 Member For: 18y 20d Gender: Male Location: balmain Posted 26/07/09 10:44 AM Share Posted 26/07/09 10:44 AM getting retuned in the next week or so at cv is it worth while putting a high flow cat in with a standard exhuast im not really after a power gain just better throttle response more than anything else ? im sure this has been asked a million times befor and ive read a few post but couldnt really find a straight answer do I need to upgrade my actuator after putting a high flow cat in the car will have the following mods , plazaman hot side pipeing , process west cold side , capa cooler direct replacement ,walbro fuel pump and bigger injectors bf mk1 6 speed auto cheers trev Link to comment https://www.fordxr6turbo.com/forum/topic/60013-cat-install-worth-it/ Share on other sites More sharing options...
rhys86 Donating Members 443 Member For: 18y 4m 12d Gender: Male Location: Wollongong Posted 26/07/09 10:50 AM Share Posted 26/07/09 10:50 AM It sure is. Standard cats choke up the exhaust even on a standard system. Link to comment https://www.fordxr6turbo.com/forum/topic/60013-cat-install-worth-it/#findComment-912334 Share on other sites More sharing options...
xr6t ego Member 1,112 Member For: 18y 4m 17d Gender: Male Location: PERTH WA Posted 26/07/09 11:23 AM Share Posted 26/07/09 11:23 AM Get a high flow cat for sure mate and even look at getting a dump upgrade aswell. The rest of the standard exhaust is good up into the 300's. Link to comment https://www.fordxr6turbo.com/forum/topic/60013-cat-install-worth-it/#findComment-912354 Share on other sites More sharing options...
Benny-4000 Member 31 Member For: 17y 2m 26d Posted 28/07/09 12:28 PM Share Posted 28/07/09 12:28 PM trevs said: getting retuned in the next week or so at cv is it worth while putting a high flow cat in with a standard exhuast im not really after a power gain just better throttle response more than anything else ? im sure this has been asked a million times befor and ive read a few post but couldnt really find a straight answer do I need to upgrade my actuator after putting a high flow cat in the car will have the following mods , plazaman hot side pipeing , process west cold side , capa cooler direct replacement ,walbro fuel pump and bigger injectors bf mk1 6 speed auto cheers trevif you are after throttle response, a dump pipe and cat will make the biggest difference. Link to comment https://www.fordxr6turbo.com/forum/topic/60013-cat-install-worth-it/#findComment-913517 Share on other sites More sharing options...
trevs Member 781 Member For: 18y 20d Gender: Male Location: balmain Posted 13/08/09 09:17 AM Author Share Posted 13/08/09 09:17 AM been calling around for a high flow cat plus install prices are all over the place how much should I be looking at around abouts and can anybody recommmend somewhere are the st peters, newtown , tempe area I need to get it done befor monday morning because the cars booked in at cv on monday cheers trev Link to comment https://www.fordxr6turbo.com/forum/topic/60013-cat-install-worth-it/#findComment-920233 Share on other sites More sharing options...
xr6t xr6t Member 49 Member For: 16y 6m 11d Gender: Male Location: northern beaches Posted 13/08/09 09:36 AM Share Posted 13/08/09 09:36 AM pm sent Link to comment https://www.fordxr6turbo.com/forum/topic/60013-cat-install-worth-it/#findComment-920241 Share on other sites More sharing options...
