TURBO4LT Member 1,533 Member For: 21y 10m 12d Gender: Male Location: NSW Posted 04/09/03 05:04 AM Share Posted 04/09/03 05:04 AM I was just wondering has anyone fitted one of the AutoMeter AIr Fuel Meters? Link to comment https://www.fordxr6turbo.com/forum/topic/5997-air-fuel-ratio-meter/ Share on other sites More sharing options...
scott52 Member 188 Member For: 22y 6m 5d Gender: Male Location: Perth, W.A. Posted 04/09/03 06:25 AM Share Posted 04/09/03 06:25 AM I've just bought one from jay-car. I'll let you know once it is fitted. I bought it because I think my car is running too rich. it uses lots of fuel even when I try to conserve it. a recent country trip at a stead 110-115 delivered an average of 11.0lt/100km Link to comment https://www.fordxr6turbo.com/forum/topic/5997-air-fuel-ratio-meter/#findComment-48082 Share on other sites More sharing options...
twinxrs Member 202 Member For: 21y 11m 7d Location: Sydney Posted 04/09/03 11:15 AM Share Posted 04/09/03 11:15 AM I'm starting to think the same thing... Fuel economy doesn't drop below 14.5 even after a long trip on the highway !I'm sure that it's running rich, as there's a fine black power on the back of the car all the time. I just washed it yesterday, so I'm going to take careful note, but I've noticed this before, 2 or 3 days of city driving (not stop-start even) and the lip on the rear bumper bar just looks like it's never been washed.The car's a citric acid, so it might just be showing the grime more than I'm used to, but has anyone else see this ? Link to comment https://www.fordxr6turbo.com/forum/topic/5997-air-fuel-ratio-meter/#findComment-48168 Share on other sites More sharing options...
Zeke zeke Member 792 Member For: 22y 9d Location: Adelaide Posted 04/09/03 12:25 PM Share Posted 04/09/03 12:25 PM That sounds a bit OTT. I trust you're restting the computer before the highway trip or using instantaneous consumption. If so, and you're getting those figures, then something's wrong! Unless you cruise at 160 or something!zeke Link to comment https://www.fordxr6turbo.com/forum/topic/5997-air-fuel-ratio-meter/#findComment-48191 Share on other sites More sharing options...
TURBO4LT Member 1,533 Member For: 21y 10m 12d Gender: Male Location: NSW Posted 04/09/03 09:14 PM Author Share Posted 04/09/03 09:14 PM Well I bought a 2 gauges air fluel and boost ill fit them on the weekend and see how we go....I usuallly get 14.5/100km that's mainly city driveing Link to comment https://www.fordxr6turbo.com/forum/topic/5997-air-fuel-ratio-meter/#findComment-48217 Share on other sites More sharing options...
Turbo6man Lifetime Members 4,084 Member For: 22y 8m 19d Gender: Male Location: South Coast NSW Posted 05/09/03 03:05 AM Share Posted 05/09/03 03:05 AM Yes, they do run rich - Ford have erred on the safe side because, I suppose, they are fully expecting people to mod their exhaust or tamper with their boost etc which generally results in the mixture leaning out a little.Running rich will drop power but also drop combustion chamber temps slightly - so you can easily understand why Ford would build in some engine protection by doing this... Link to comment https://www.fordxr6turbo.com/forum/topic/5997-air-fuel-ratio-meter/#findComment-48292 Share on other sites More sharing options...
Ford_Power Member 798 Member For: 22y 2m 29d Posted 05/09/03 12:44 PM Share Posted 05/09/03 12:44 PM Turbocharged cars are generally run richer so as to keep the combustion chamber temperature down and given worst case conditions (eg high engine temp, heavy load) the engine will not ping, and thus get damaged.Although, it is worth pointing out that it is generally at WOT that the mixture is set to run rich and not at stoic. The mixture should not really be rich under part throttle. (cruise)Ross Link to comment https://www.fordxr6turbo.com/forum/topic/5997-air-fuel-ratio-meter/#findComment-48403 Share on other sites More sharing options...
TURBO4LT Member 1,533 Member For: 21y 10m 12d Gender: Male Location: NSW Posted 05/09/03 11:11 PM Author Share Posted 05/09/03 11:11 PM Well Ive fitted the Boost and air/fuel meters, and it runs in closed loop cycling pretty quickly at idle and cruise. Under part load like 1 to 2 psi it still works in closed loop . When you floor it boost goes to 5psi and mixture sits on 12:1 steady. A few times when I plant it , the boost spikes to 10psi especially when the traction control comes in , feels good whilst it hits 10psi but quickly goes back to 5psi. Link to comment https://www.fordxr6turbo.com/forum/topic/5997-air-fuel-ratio-meter/#findComment-48431 Share on other sites More sharing options...
