senna_T Forged Member Lifetime Members 15,818 Member For: 17y 11m 26d Gender: Male Location: SW Sydney Posted 07/10/09 09:18 PM Share Posted 07/10/09 09:18 PM It still drives, so I'm just going to keep giving it hell. I have my eye on another centre that should fix it. Just couldn't be biggered pulling the cradle out right now! Link to comment Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 6m 25d Gender: Male Location: OZ Posted 08/10/09 02:49 AM Share Posted 08/10/09 02:49 AM I replaced my standard bush as I had some rear end noise....fitted the superpro bush and replaced the other bushes while I was there and I still have rear end noise...creaks and clunks etc. I'm with Senna...I'm just ignoring it until it breaks as I can't be bothered atm. Link to comment Share on other sites More sharing options...
Daneo 330 Member 14 Member For: 15y 7m 15d Posted 08/10/09 08:19 AM Share Posted 08/10/09 08:19 AM hahahah yep!!! im in the same boat!!! going to check the bolts are fine and leave it at that!!!! maybe il find out the realll problem the hard way when I get a new tune and run some more power through her :-D Link to comment Share on other sites More sharing options...
seduced Need more power. Now taking donations. Member 753 Member For: 15y 11m 6d Gender: Male Posted 04/11/09 02:20 AM Share Posted 04/11/09 02:20 AM Steve - Nice job, but I was wondering about taking this even further with the baffling you mentioned in the first post. Some exapndable foam within the chassis blocks would certainly help, but would it trap moisture and cause rust? Also, I will be creating some sort of rubber bush to go between the chassis mount bolt and the diff cradle to further reduce noise.I am really keen to add foan wherever possible, is there a certain brand/type that works best? Rust is my only concern... any ideas? Link to comment Share on other sites More sharing options...
Guest STEVE_BAXR Guests Posted 06/11/09 10:08 PM Share Posted 06/11/09 10:08 PM It should not trap moisture but you could rust prof it 1st then put the foam in so that the foam traps the oil. The chassis mount bolt from the diff to the car that is F++ked why they did that ? and no bush ?.Today I will be having a look at the bush to see how it is holding up .. Link to comment Share on other sites More sharing options...
Guest STEVE_BAXR Guests Posted 07/11/09 09:25 PM Share Posted 07/11/09 09:25 PM The news is good I have done about 10,000km with the new bush in, and new bush is all good no crack's and it still move's the same when loaded up. Link to comment Share on other sites More sharing options...
straughsberry Donating Members 1,846 Member For: 17y 5m 15d Gender: Male Location: Broady, Melbourne Posted 08/11/09 02:19 AM Share Posted 08/11/09 02:19 AM Good work mate. This kind of real world experience is invaluable. Link to comment Share on other sites More sharing options...
Smoke them tyres Member 557 Member For: 17y 1m 11d Gender: Male Location: Brisbane Posted 08/11/09 11:24 AM Share Posted 08/11/09 11:24 AM Quote This kind of real world experience is invaluable. .....spot on. Link to comment Share on other sites More sharing options...
Full Monty Member 513 Member For: 17y 7m 10d Gender: Male Location: Melbourne Posted 08/11/09 11:16 PM Share Posted 08/11/09 11:16 PM Thanks for the update, good to hear. Link to comment Share on other sites More sharing options...
seduced Need more power. Now taking donations. Member 753 Member For: 15y 11m 6d Gender: Male Posted 11/11/09 01:35 AM Share Posted 11/11/09 01:35 AM Steve - Was thinking of filling the hollow mounting blocks with SikaFlex227 for vibration absorbtion. Also, Rubber pad between bolt and frame, and also vibration deadening on the entire crossmember, support bracket (the one with that stupid bolt) and accross the entire rear diff cradle. If I can stop the vibration at the source, it will mean less noise transferred. Therefore less noise to dampen in the cabin.What do you reckon? Any underbody products you recommend? Link to comment Share on other sites More sharing options...
