senna_T Forged Member Lifetime Members 15,818 Member For: 18y 2m 28d Gender: Male Location: SW Sydney Posted 05/09/09 12:53 PM Share Posted 05/09/09 12:53 PM The other problem is that the diff housing is basically the mount to the body in commodores - where as the falcon has a sub frame... Link to comment https://www.fordxr6turbo.com/forum/topic/59908-nolathane-diff-bush-noise-fix/page/6/#findComment-929661 Share on other sites More sharing options...
Guest STEVE_BAXR Guests Posted 10/09/09 10:40 AM Share Posted 10/09/09 10:40 AM On 03/09/2009 at 4:54 AM, eblis said: Any one know if the new version of the Superpro diff bush for a BF is available yet? Is it part #SPF3232K?that is the old bush part number Link to comment https://www.fordxr6turbo.com/forum/topic/59908-nolathane-diff-bush-noise-fix/page/6/#findComment-931518 Share on other sites More sharing options...
eblis New Member 9 Member For: 20y 6m 28d Posted 10/09/09 09:07 PM Share Posted 10/09/09 09:07 PM So is the new bush available yet? BF part #? Link to comment https://www.fordxr6turbo.com/forum/topic/59908-nolathane-diff-bush-noise-fix/page/6/#findComment-931654 Share on other sites More sharing options...
f-wolf Member 897 Member For: 18y 10d Gender: Male Location: ACT Posted 11/09/09 02:47 AM Share Posted 11/09/09 02:47 AM (edited) On 10/09/2009 at 9:07 PM, eblis said: So is the new bush available yet? BF part #?Found here: http://203.31.191.243/fulcrumCat/ Edited 11/09/09 02:52 AM by f-wolf Link to comment https://www.fordxr6turbo.com/forum/topic/59908-nolathane-diff-bush-noise-fix/page/6/#findComment-931756 Share on other sites More sharing options...
eblis New Member 9 Member For: 20y 6m 28d Posted 11/09/09 02:52 AM Share Posted 11/09/09 02:52 AM Thanks f-wolf Link to comment https://www.fordxr6turbo.com/forum/topic/59908-nolathane-diff-bush-noise-fix/page/6/#findComment-931757 Share on other sites More sharing options...
RMGT Member 9 Member For: 19y 9m 22d Posted 05/10/09 11:06 PM Share Posted 05/10/09 11:06 PM so would some say that the fulcrum bush is a better replacement then the pedders.Ive had the pedders obe fitted to my BA GT and find it harsh and noisey. Link to comment https://www.fordxr6turbo.com/forum/topic/59908-nolathane-diff-bush-noise-fix/page/6/#findComment-940282 Share on other sites More sharing options...
straughsberry Donating Members 1,846 Member For: 17y 8m 17d Gender: Male Location: Broady, Melbourne Posted 06/10/09 02:04 AM Share Posted 06/10/09 02:04 AM On 03/09/2009 at 3:28 PM, turbotrana said: If I were to solve (or substantially help) this problem (I really haven't looked into it much) I would consider doing a double bush set up. This would mean fabricating a diff hat that has two bolt points for the bushes and there seems to be room where you could fabricate a mount to weld on the diff cradle where you could put two bushes side by side. It may mean cutting the original bush mount on the diff cradle and repositioning it to the LHS a little so the second bush could be accomodated.From those videos that were posted its clear that there is mainly up and down movement in the bush area and two bushes are possible.Anyone with any thoughts on this.I was just talking about the exact sort of solution with my cousin the other night. My words were "two or three bushes" but 2 would probably be ample With my build well on the way, I've been thinking ahead and what/how I might tackle the rear part of the drive line. I would really like to stay with the IRS and never have to resort to a 9 inch conversion. For the money you'd spend on a 9 inch conversion, I reckon a 2 bush solution could be developed and we'd have an awesome alternative to the currect best-practice of reverting back to 1971.If anyone is interested in persuing this, perhaps we could get a little team together and pool resources to tackle this proper. Unless it's already being done? Link to comment https://www.fordxr6turbo.com/forum/topic/59908-nolathane-diff-bush-noise-fix/page/6/#findComment-940308 Share on other sites More sharing options...
Daneo 330 Member 14 Member For: 15y 10m 17d Posted 06/10/09 11:11 AM Share Posted 06/10/09 11:11 AM Hay guys, I am having a fair few issues with my Ba xr6 T, the old bush F*d out so we replaced it with the fulcrum one, then few days the diff started knocking again so we had a look to find out the bolt was loose, tightened up again and away I went, drove around for a couple more days and the diff knok was back again, took her off the road pulled the whole rear assembly out to replace the front two bush's aswell, and we also found that the thread was F**d in the diff for the centre bush, soooooo we put in a new thread using a Helicoil kit and also got a stronger 12.9 grade alan head bolt, put it all back together, drove it for a day and from what I can hear there is definately a noise coming from the diff again, not sure exactly what but sounds like how it started off the first time, we are going to check the bolt tomorrow and check it all over see if its all good, the helicoils seem to go in and work out perfectly soo it either just is f*cked orr I was thinkng maybe its just the noise these bush's make but as steve posted I to also have the FULCRUM version and he said it has not made a single noise sooo yeh, anyy ideas on what to do if the helicoils just arent strong enough???? Link to comment https://www.fordxr6turbo.com/forum/topic/59908-nolathane-diff-bush-noise-fix/page/6/#findComment-940571 Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 18y 2m 28d Gender: Male Location: SW Sydney Posted 06/10/09 10:48 PM Share Posted 06/10/09 10:48 PM Maybe look at your diff centre, they are known to have a heap of play from the factory and the rubber bush just hides alot of noise. We fitted the super-pro bushes to my car and it made it vedry evident my diff is no longer happy... Link to comment https://www.fordxr6turbo.com/forum/topic/59908-nolathane-diff-bush-noise-fix/page/6/#findComment-940651 Share on other sites More sharing options...
Daneo 330 Member 14 Member For: 15y 10m 17d Posted 07/10/09 01:33 PM Share Posted 07/10/09 01:33 PM Really so what did you do about the noise??? Didnt get the chance to check the bolts n stuff today but going to get on to it asap! My biggest worry is if I have to replace my diff as it is a malwoods upgraded diff with lots of $$ spent on it!!! Link to comment https://www.fordxr6turbo.com/forum/topic/59908-nolathane-diff-bush-noise-fix/page/6/#findComment-940953 Share on other sites More sharing options...
