Nolathane Diff Bush Noise Fix?
Guest STEVE_BAXR
  • Guests
I have just put a new diff bush in and I have to say the noise is bad , so I had to have a look to see why ? there has to be a fix for it.
I am a BMW panel tech and the BIG thing that BMW is good with is no noise in the car . The nuisance noise that occurs in these pillars is related to power train, wind, tire, and road noise. Over the years, various solutions have been used to minimize the energy level of noise that flows from these sources to these pillars. A current approach is to block the path of noise with heat reactive, expandable sealing materials mounted to support plates to create a"baffle". Baffles are strategically located within the body structure in a pattern that helps to eliminate propagation of noise into the vehicle passenger compartment.
The good and bad news is to save money ford don't put any acoustic baffle or sound pads in but to stop the noise but we can.
The big part that makes all the noise in the BA is that the boot floor is like a dum , The nuisance noise come's from the diff into the diff bush then into the body. If you have a look under where the diff bush is there is a metal brace going to a nice matel box, and in the box is air NO EXPANDABLE ACOUSTIC BAFFLE ..... thanks ford .
So in the next week I will be looking more into it and filling the air with expandable sealing foam and adding some sound pads to the boot floor..
Edited by seventytwo
Please continue
https://www.fordxr6turbo.com/forum/topic/59908-nolathane-diff-bush-noise-fix/
  • Member For: 17y 10m 9d
Look forward to seeing what you come up with, I too have the polyurethane diff bush, and the noise can be bothersome...Im going to be installing sound deadening underneath the rear seat, to lessen the NVH entering the cabin, from both the diff and fuel pump. Probably do the spare wheel well and boot also.
  • Forged Member
  • Member For: 18y 2m 25d
We will be working with Super Pro to look at making a voided diff bush, this will allow a litle bit of movement in the bush in an effort to reduce NVH
Guest STEVE_BAXR
  • Guests
yes the nice blue bush from Super Pro that's the one polyurethane
  • Forged Member
Good to hear mate, the guys are really commited to making their product the best it can be
  • 3 weeks later...
Guest STEVE_BAXR
  • Guests
OK I have the new test diff bush from Fulcrum, I have some photo's just to show how easy it was to put in MY WAY in under 20min .
photo's show the old bush coming out and the new bush going in................ :spit: and the tools to do the job.
The jack in the photo is just to hold the diff up to make it easy to put the bolt back in.
Next is to take it for a drive to see if the NVH entering the cabin are not there or they are lower ..
  • Member For: 20y 3m 17d
photo's show the old bush coming out and the new bush going in................ :o and the tools to do the job.
Doesn't the standard method of replacing the bush involve dismantling the entire rear cradle and involve approximately $900 of labor?
You come along and figure out how to do the same thing from the boot in 20 minutes and a couple of tools?
This is simply brilliant.
Congratulations.
:useless::spoton::bowdown:
Regards,
aa
