ratter Member 6,793 Member For: 18y 11m 2d Gender: Male Location: @ my laptop Posted 11/08/09 08:54 AM Share Posted 11/08/09 08:54 AM His symptons are exactly what valve springs cause.I would feel bad for him if he paid $1200 + labour and it did not fix his problem. Link to comment https://www.fordxr6turbo.com/forum/topic/59906-missing-problem/page/2/#findComment-919328 Share on other sites More sharing options...
flutterpast Member 11 Member For: 15y 11m 18d Posted 12/08/09 11:07 AM Author Share Posted 12/08/09 11:07 AM thanks guys ill get a price to get the springs done and see what happens. I asked my mechanic about valve float and he said it probably wouldnt be that but yeah not sure.its strange though I can put as much boot in as I want when its getting traction.. it only happens when ive been smokin it on the brake Link to comment https://www.fordxr6turbo.com/forum/topic/59906-missing-problem/page/2/#findComment-919865 Share on other sites More sharing options...
notol Team Octane Donating Members 209 Member For: 16y 5m Gender: Male Location: Innisfail Nth Qld Posted 12/08/09 11:13 AM Share Posted 12/08/09 11:13 AM just a thought, but could it possibly be coils? Link to comment https://www.fordxr6turbo.com/forum/topic/59906-missing-problem/page/2/#findComment-919870 Share on other sites More sharing options...
Sasha Member 141 Member For: 17y 8m 21d Gender: Male Location: North Queensland Posted 12/08/09 02:17 PM Share Posted 12/08/09 02:17 PM ratter said: His symptons are exactly what valve springs cause.Ahh fair enough. Perhaps you are right, its just that I have only heard people talk about this happening and never seen it. Theres plenty of other OHC engines with bucket type lifters that don't suffer. I thought it may effect the immediate idle quality after a high rpm ramp if it was going to have an effect at all, aparently im wrong. I definitely didnt think it would last for 2 mins as flutterpast describes. But oh well. Link to comment https://www.fordxr6turbo.com/forum/topic/59906-missing-problem/page/2/#findComment-919975 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 2d Gender: Male Location: @ my laptop Posted 12/08/09 10:34 PM Share Posted 12/08/09 10:34 PM When the valves float, they are basically bouncing around out of control and the rocker arms are no longer contacting the cam shaft, when this happens the lifters have no load on them and then some will pump full of oil. When the lifter is full of oil it will hold the valve off it's seat so basically dropping compression on that cyclinder. This is why the car will run rough, after a few minutes of running the lifter will then bleed back down and things will go back to normal.This is the good scenario, the bad one is if the valves bounce hard enough, the collets can dislodge and the valve falls into the combustion chamber, colliding with the piston and doing lots of damage. Link to comment https://www.fordxr6turbo.com/forum/topic/59906-missing-problem/page/2/#findComment-920041 Share on other sites More sharing options...
Sasha Member 141 Member For: 17y 8m 21d Gender: Male Location: North Queensland Posted 13/08/09 04:30 AM Share Posted 13/08/09 04:30 AM Thanks for the explanation ratter, it makes sense. I can understand the correlation between valve bounce and lifter pump. It was just hard to imagine these engines suffering valve float where the stock rev limiter is set. So it must be a hit and miss wether your engine has a batch of weak springs as there are plenty of BA's around that are making between 300 and 350 rwkw without any symptoms on stock springs. Link to comment https://www.fordxr6turbo.com/forum/topic/59906-missing-problem/page/2/#findComment-920129 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 11m 2d Gender: Male Location: @ my laptop Posted 13/08/09 07:47 AM Share Posted 13/08/09 07:47 AM When you increase boost you are effectively lowering the seat pressure on the inlet valves, because the extra boost is pushing against the inlet valve, so for example if you had a spring with 160 lb seat pressure, with 15 lbs of boost you effectively only have 145 lb of seat pressure Link to comment https://www.fordxr6turbo.com/forum/topic/59906-missing-problem/page/2/#findComment-920200 Share on other sites More sharing options...
flutterpast Member 11 Member For: 15y 11m 18d Posted 19/08/09 12:55 PM Author Share Posted 19/08/09 12:55 PM notol at first I thought it might be coils but it seems strange that faulty coil packs would cause the oil light to flash so I dunno Link to comment https://www.fordxr6turbo.com/forum/topic/59906-missing-problem/page/2/#findComment-922562 Share on other sites More sharing options...
