XR6TBAMK2 Member 12 Member For: 17y 6m 28d Gender: Male Location: SW SYDNEY Posted 23/07/09 06:19 AM Share Posted 23/07/09 06:19 AM Gday all, Ive had a problem with my 4 speed auto for a while now so I ended up getting it strenghtened.Usual mods done to box, heavy duty clutch packs,bands and line pressure etc.The main problem, apart from the usual slipping clutches was that it was seeming to be getting stuck in between gears,mainly 4th but sometimes 3rd and would start shuddering. To fix the problem, I would either have to back off the throttle and the box would eventually fall back into place or put my foot down and 'sometimes' it would drop back into the lower gear.This would happen without driving the car hard also.I thought after having the box rebuilt that it would go away but it hasnt.The gearbox builder seems to think that it must be something electronic somewhere.Has anyone had this problem happen to them? The car is putting out 330rwkws street and 352rwkws on race. Any help would be much appreciated.Thanx Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 9m Gender: Male Location: central coast Posted 23/07/09 08:57 AM Share Posted 23/07/09 08:57 AM who's tuning the car , lots of issue's with the 4spd if the tuner can't tune them it's basically 50% of the way the box works .have you had it retuned since you had the box built Link to comment Share on other sites More sharing options...
Rootster Just a large member member Silver Donating Members 3,125 Member For: 16y 3m 11d Gender: Male Location: sydney Posted 23/07/09 09:31 AM Share Posted 23/07/09 09:31 AM well I think you should find out what controls the gear change...are they controlled electrically with a solenoid or through the valve body....Mate I'm an old school mechanic and really don't know what controls these new cars..If the box changes electrically well could be in the tune.....If not did they fit a shift kit to the box.....If so the springs in the valve body may be to hard causing this problem...... Link to comment Share on other sites More sharing options...
XR6TBAMK2 Member 12 Member For: 17y 6m 28d Gender: Male Location: SW SYDNEY Posted 23/07/09 09:36 AM Author Share Posted 23/07/09 09:36 AM A top sydney tuner has done all the work on the car,I was going to wait to run the box in before getting a retune.I had the gearbox settings that were on the capa box taken back to standard,including the torque tags as it was causing dramas for the auto builder.The builder couldnt raise the line pressure on the box unless the all the settings were removed.The box feels stronger and shifts alot harder but it still has that problem....just cant figure it out. Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 9m Gender: Male Location: central coast Posted 23/07/09 09:37 AM Share Posted 23/07/09 09:37 AM it's all controlled by line and ramp pressures of the fluid wich is controlled by the ecu Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 9m Gender: Male Location: central coast Posted 23/07/09 09:38 AM Share Posted 23/07/09 09:38 AM c&v maybe ???? Link to comment Share on other sites More sharing options...
Rootster Just a large member member Silver Donating Members 3,125 Member For: 16y 3m 11d Gender: Male Location: sydney Posted 23/07/09 09:38 AM Share Posted 23/07/09 09:38 AM so if its shifts harder he played around with the springs in the valve body?????? Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 9m Gender: Male Location: central coast Posted 23/07/09 09:41 AM Share Posted 23/07/09 09:41 AM maybe but a slipping box takes a lot of line pressure for a good shift if it's been rebuilt and still running the old settings it would be shifting harder Link to comment Share on other sites More sharing options...
Rootster Just a large member member Silver Donating Members 3,125 Member For: 16y 3m 11d Gender: Male Location: sydney Posted 23/07/09 09:46 AM Share Posted 23/07/09 09:46 AM was the converter replaced......don't they have a pressure regulator valve... Link to comment Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 21y 9m 2d Gender: Male Location: Victoria Posted 23/07/09 10:04 AM Share Posted 23/07/09 10:04 AM Stuffing about with valve bodies to increase pressure is old hat now.The best approach is to rebuild them to standard trim with a few little tweaks.I went through all end of dramas with the 4 speed in my old BA.Oh, there's no such thing as high friction clutches and bands. OEM parts are the only parts available for these boxes. Link to comment Share on other sites More sharing options...
